April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Old 07-18-2012, 07:54 AM
Cobra Make, Engine: A&C 427 s/o
Default 427 fe
has anyone put a 427 Fe engine in ther cobra if so how did you get the measurements to know where to mount the motor mounts on the frame rails.
Old 07-18-2012, 09:33 AM
FWB's Avatar
FWB FWB is offline
if the rear is already mounted, you will kinda have to work from the back front.
mock up a block and your trans to be sure you have enough room for a driveshaft....it'll be quite short. have the mounts on the engine
things to consider...
oil pan to ground clearance,
carb and aircleaner to hood clearance, watch out for this one...
pinion angle
Fred B
Old 07-18-2012, 12:29 PM
Default No
I have a FE in my A&C and follow Joes manual.... Take a measurement from the cross member to the center between cylinders #2&3's exhaust port on the Pass side. The distance is 22.5 inchs so your headers and side pipes will fit.
Jon
Old 07-23-2012, 08:53 AM
The 22 1/2" is correct but I would put the headers that you will use on the FE and install the mounts on the block and mock it up that way. I used the headers from AC and they are formed to fit around the foot box. I had to have the passenger side fixed so that it would not hit the foot box.
