Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Old 09-14-2012, 09:05 AM
Cobra Make, Engine: Contemporary Cobra
Default Where to Insulate ??????
Getting ready to insulate inside with a fiberglass tub....is behind the seats on the rear wall and in the trunk nessary ? The front firewall, floors and tunnel will be done am I really missing an area thats needs it?
Jon
Old 09-14-2012, 11:48 AM
FUNFER2's Avatar
I would add behind the seats/rear wall for sure, and if you have enough you could also do the trunk, but it's not a necessity. Are you doing the doors ?
Regards,
Kevin
Old 09-14-2012, 01:42 PM
Cobra Make, Engine: Antique&Collectible 392 stroked
I used lizzard skin and sprayed the whole interior section and it seems to be working great
pops67
Old 09-14-2012, 02:10 PM
PNJSNAK's Avatar
Club Cobra Member
Cobra Make, Engine: A&C 427S/C, 351W, T5
Jon:
I did not do the area behind the seats because I wanted as much room as possible.
I also did not do the trunk. Both areas only have carpet.
I did insulate all surfaces of the footboxes, half the floor and the tunnel.
I did not do the floor under the seats.
I guess, it is what you feel you need to insulate.
If you are thinking to insulate against the heat, then what I did was about all you need to do.
If you are insulating against road noise, let me tell you that the NOISE coming out of the sidepipes no more than a couple feet from your ears, will be louder than any road noise.
Jim
OhioCobraClub.com
Old 09-14-2012, 03:03 PM
snakebitekit's Avatar
Cobra Make, Engine: ERA FIA #2119
I used Dynomat and did behind the set, foot boxes, tunnel,under the seats and even the small panel in the door. Boxes and tunnel was primarily for heat the doors and rear were done to create a solid feel. When my door closes it goes THUNK. I am sure it helps with road noise but withthe pipes who can tell.
Old 09-14-2012, 04:34 PM
venum14's Avatar
Cobra Make, Engine: Bennett Cobra
Jon:
The fiberglass will provide some insulation but I would be most concerned with the areas of the footboxes near the headers. Without insulation, you will have a built in heater for your feet and legs. Since I live in the California Central Valley we have plenty of summer heat so I didn't want my shoes melting. This is what I did but I have aluminum foot boxes and interior panels:
1. Double walled the front and engine side of the foot boxes (Kevlar/foil backed insulation sandwiched between the two layers of aluminum)
2. Installed Dynamat Extreme to all the interior panels including the firewall
My car can be driven comfortably in the summer and I even crusie in summer parades with shorts. In my opinion, a little time and money spent on insulation will avoid ripping out the interior and doing it again!
Jeff
