Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
November 2024
  #21 (permalink)
Old 03-02-2013, 07:55 PM
Cobra Make, Engine: acc
Default baffles
Ok, opened up the side pipes, both baffles were loose and man did they restrict the flow. So I left the baffles out, way too loud. So I cut the side pipes open again and installed a set of schoenfeld baffles much better. Right now we just finished wet sanding and started buffing the gel coat. Those of you that have gel coat that have not done this need to. I could not believe how much deeper the shine and the orange peel is gone. I thought it looked great before not even close. I'll post some pics as soon as were are done.
Dave
  #22 (permalink)
Old 03-03-2013, 08:17 AM
rcobrakit67's Avatar
Cobra Make, Engine: Antique and Collectible Autos 408w
I called Joe and he said the sidepipes are 3" inside diameter. Is this true? I'm probably ordering the sidepipes this week. I have so many other things to purchace right now i figure i can always go back and modify them at a later date. I cant wait to see the body buffed out.
  #23 (permalink)
Old 03-03-2013, 10:47 AM
Cobra Make, Engine: Contemporary Cobra
Default Sidepipes
A&C's side pipes work quite well...Joe has a 500hp 427 in this cobra and I used them with a 457 hp 428. I damaged one and replaced both muffles with Classic Chambered Mufflers....like the sound better, easy to install
that being said you can't go wrong with the pipes from A&C
Jon
  #24 (permalink)
Old 03-05-2013, 02:26 PM
Default size
They measure 3.875 inches on the ID. I had to modify the new baffles to fit. The old baffle was very small, too much restriction for me. I want all the HP I can get.
  #25 (permalink)
Old 03-17-2013, 02:21 PM
Default done
Car is back together, took it for a little drive Friday evening. Holly crap I thought it was nasty before. I have a ton more HP than last year. You bump the throttle too much it starts spinning the tires. Has anyone had trouble with wheel hop? It's not terrible but it's there. I was told the rubber rod ends on the 4 link can cause that. So I'm replacing them soon, just wondered if anyone else has had this problem.Thanks,
Dave
  #26 (permalink)
Old 03-18-2013, 06:41 AM
PNJSNAK's Avatar
Club Cobra Member
Cobra Make, Engine: A&C 427S/C, 351W, T5
Be careful, what tires are you running on the back.
Also, love to see a pic of the car after to wetsanded and buffed it.
I know in the past you said you poseted pics.
Where did you post them?
You can copy them into your post or most post them in their gallery and you get to it by clicking on the little camera icon ubder your screen name.
Jim
OhioCobraClub.com
  #27 (permalink)
Old 03-18-2013, 11:18 AM
rpatton3's Avatar
Cobra Make, Engine: Backdraft 874 solid red Roush 427 small block 515 hp
I got my sidepipes back from StainlessSteel Headers but have not gotten them on car yet. Externally, they look almost the same as before.
Internally, I have 3" diameter straight through vs. two tiny mufflers per side. Backdraft had those as standard OE until #900 or so and I was lucky enough to have #874.
There were no atheists in the foxholes.
