Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Old 08-26-2016, 07:48 PM
Cobra Make, Engine: Contemporary Cobra
Default Wilwood MC failure
Took the car to dinner tonight and had to hit the brake pedal hard to stop the car
No issues... Drove a little father to park, steped on the brakes and the pedal went to the floor. MC has fluid, no leaks, pedal is connected to the MC shaft! Any thoughts what happened?
Jon
The Impossible Only Takes A Little Longer
Old 08-27-2016, 05:35 AM
Xack's Avatar
Cobra Make, Engine: West Coast Dreams
Plunger seal failed in your MC
Old 08-27-2016, 05:54 PM
Dwight's Avatar
Smile
buy a rebuild kit. It's just a o ring and a rubber cup.
Old 08-28-2016, 08:04 AM
Default Resivour is dry...
Made a mistake....no fluid in the resivour and no leaks
Where is the brake fluid?
Jon
Old 08-28-2016, 11:16 AM
mrmustang's Avatar
Gold Star Contributor
Jon
Just a thought, but have you refilled and bled the system, then had Jane hold her foot on the brake peddle to add pressure to the system so you could actually check for leaks and or a failed seal?
Could it have all leaked on, and burned off the header, and/or collectors?
Bill S.
Old 08-29-2016, 01:15 AM
Gaz64's Avatar
Made a mistake....no fluid in the reservoir and no leaks
Jon
The fluid is where the brake pad material used to be.
The reservoir must be too small.
