Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
December 2025
Like Tree3Likes
  • 1 Post By cobrabritt83
  • 1 Post By scootter
Old 12-11-2021, 02:41 PM
Cobra Make, Engine: A&C 427 s/o
Default wheel well protection
I'm looking to see what people have used to protect their paint job from stones hitting the underside of the wheel well. I have already used a rubber spray on bedliner coating in the wheel wells, but it doesn't seem like that's going to be enough to protect the fiberglass body from getting star cracks in the paint. I have seen some people have used spray foam or glued on foam matts. I'm not sure if these have worked or have lasted.
Old 12-11-2021, 09:59 PM
Cobra Make, Engine: SPF832, 466cid
I have Avon tires so I purchased 1/4" neoprene sponge foam rubber sheets from Amazon. I cut patterns for all fenders and used 3M spray adhesive to install.
Old 12-12-2021, 04:11 PM
Cobra Make, Engine: MidStates, 351C, 4spd, 9"
Send a message via AIM to krausewich
Home Depot or Lowes?? Have 1/4" firm rubber flooring that I was considering. It is in the carpet/flooring section. This would be VERY good protection if you find the right adhesive ; ) Cut some slits across the backside so it contours well, then contact cement away. I have a slight star in my front fender that I would like to avoid seeing again!
I know I saw it on a 2' wide roll by the foot, or 4' precut in different lengths.. Like this
https://www.homedepot.com/p/Rubber-C...B-13/314377937
"It's not about getting from point A to point B. It is the point"
-J. James
M. Krause
1.508.944.3368
Old 04-19-2022, 11:49 AM
I ended up using 1/4" neoprene sponge from amazon, https://www.amazon.com/dp/B07WFX5713...C6S2F8GQ0AJG51 and 3m super 77 spray. So far everything has held up.
msinc likes this.
Old 04-19-2022, 10:18 PM
scootter's Avatar
Cobra Make, Engine: SPF #1436 514
I have about 60k miles on my car with just the rubberized undercoating with no issues.
Old 04-19-2022, 10:20 PM
scootter's Avatar
I have about 60k miles with the rubberized undercoating in the wheels wells with no issues.
CompFi likes this.
