-   Antique & Collectibles (http://www.clubcobra.com/forums/antique-collectibles/)
-   -   Rear Discs (http://www.clubcobra.com/forums/antique-collectibles/63684-rear-discs.html)
AMiller 04-20-2005 11:49 AM
Rear Discs
Im getting ready to powdercoat the rear axle and was looking at the brake line layout. My question is on the mounting of the flexible line from the caliper to ?????
Is there a mounting plate that needs to be welded to the rear? Does it go to the frame?
Second question is on the axle vent. My kit came with a weak looking plastic vent. Has anyone used something different? Before I start the search I would love a quick suggestion.
Thanks,
Aaron
Rick Parker 04-20-2005 01:29 PM
I used a fitting welded to the axle tube and then a formed hose that curves around the link bar. It works perfecly.
[IMG]http://www.clubcobra.com/photopost/d...re_417-med.jpg[/IMG]
Haz331 04-21-2005 06:14 AM
Aaron, I had the same question. I found the flexible line to be very short and difficult to mount anywhere. I ended up welding a small tab on the axle tube. I did use the plastic vent although I did consider upgrading to a vent offered by Summit. I figured that if it vents and is out of sight , it's probably good enough.
Roscoe 04-21-2005 06:44 AM
Do yourself a favor and get this from Pegausus Auto Racing
http://www.pegasusautoracing.com/Images/M/4651.JPG
http://www.pegasusautoracing.com/pro...asp?RecID=2915
They are 12 bucks each. You can drill the chassis and mount them very securely. Then get the stainless braided brake hose. You can buy them in different lengths to fit your application.
Roscoe
