Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
December 2025
Old 06-18-2005, 11:17 AM
jerry w's Avatar
Cobra Make, Engine: Antique & Collectable 302, C-4,Ford 9 inch
Default Electronic Speedometer help
Where do I connnect the sending unit on a C-4 transmission for an electronic speedometer? Any help appreciated!
Jer
Jerry
Old 06-18-2005, 01:14 PM
Woodz428's Avatar
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
Arrow
It goes into the speedo drive hole. Usually a stock Ford speed sensor from a later Ford is compatible with most electronic speedos. The ones that usually come with the speedo have a threaded drive instead of the clamped in Ford design.
WDZ
Old 06-18-2005, 01:16 PM
jerry w's Avatar
WDZ,
thanks for the reply, can I get a sensor from a Ford dealer (OR NAPA) that will fit my C-4?
Jer
Jerry
Old 06-18-2005, 01:59 PM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
You must make sure the gears mesh.
If they are in the same direction, they will not turn and the speedo gear will destroy the sending unit gear.
Just my opinion.
