-   Antique & Collectibles (http://www.clubcobra.com/forums/antique-collectibles/)
-   -   panard bar (http://www.clubcobra.com/forums/antique-collectibles/92889-panard-bar.html)
saltshaker 11-07-2008 05:35 AM
panard bar
I bought one...does anyone have a picture of one installed or advice on how it's done?
Clois Harlan 11-07-2008 08:26 AM
Contact Lew Payne he has an A&C and has had a new panhard bar installed in his and might have some nice photo's for you. Pm me and I will send you his email adress.
Clois Harlan
Jimv455 11-08-2008 05:48 AM
When I was at A&C six months ago they had a rolling chassis in the show room with a panhard bar installed. How you install the bar will vary with what type you bought. Some need to have a bracket welded to the frame other ones bolt on. The other end of it need to be secured to the rear axle again a barcket either needs to be bolted or welded on. The one I rember seeing at A&C was welded..
Here's an article that might help..
http://www.afcoracing.com/tech_pages/panhard.shtml
saltshaker 11-08-2008 06:31 AM
panard bar
my bracket can be installed either way...after looking at the link I think i will call joe becauce the bar attaches to the top of the diff., are you using one on your car?
Jimv455 11-08-2008 08:49 AM
No but it's on my list of possible upgardes. I have to get a stablizer bar in there first.. Do you have one?
saltshaker 11-08-2008 11:34 AM
stablizer bar
no, did't know they offered one..where are you getting it from?
rdc767 11-08-2008 10:41 PM
Here is a picture of mine installed. Don't install it without the body on. The height of the frame will drop with the weight and bind up the bar. It definitely limits suspension travel. I mounted mine before the body was on. I had to lower the frame mounting bolts about 1" to get some travel back.
http://www.clubcobra.com/photopost/d...um/panard1.JPG
saltshaker 11-09-2008 06:15 AM
panard bar
is the picture before or after you moved it?
rdc767 11-09-2008 10:03 AM
This is as is. I had to take the left wheel off to take the picture but the axle is supported with a jackstand so it has a load on it.
I think I had to shorten the bar and rethread it (maybe a 1"). If the bar is mounted to high up it binds up the suspension travel. I think the lower the better on the frame. If its too low it will contact the third member. :JEKYLHYDE
So far 10 miles the ride seems pretty good and with not aligning the front yet but it handles ok. Really haven't taken any corners hard yet!:eek:
SuperHart 11-09-2008 10:31 AM
I'm not sure if the photos of my installation will help much but they are the only ones I have. I installed the bar in a lower position to make adjustment easier. Since my car sees no track time the only purpose of the panhard bar is to prevent lateral movement of the rear end assembly. The inside bracket was fabricated from 0.25 steel plate and attached to two lower bolts on the pinion bearing retainer on the carrier. I used Grade 8 bolts 0.25 longer than stock and cross drilled the heads for safety wire. The outside bracket was welded to the chassis in a convenient location.
http://home.comcast.net/~superhart/cobra04-29-01d.jpg
http://home.comcast.net/~superhart/cobra04-29-01f.jpg
saltshaker 11-09-2008 02:08 PM
thanks
Thanks, the picture helps. Jon
Automan 11-11-2008 10:17 PM
Sorry guys but i just need to ask this question. What is the purpose of this part?
Automan
TButtrick 11-12-2008 03:55 AM
In the cases here, it locates a solid axle left to right with respect to the frame and limits the axles left to right movement while allowing maximum suspension travel.
eddytheb 01-10-2009 08:27 AM
My 2 cents on this one. I use them, I love them, there not a big cost and it makes a great deal of difference in the handling of the car. But as with any thing it needs to be installed right to optimize its ability. This is also something that is best done with all the weight in and on the car and supported by the tires. Try and mount the frame rail bracket so that the link bar is as close to level as possible. Weld it to the frame if at all possible there is a lot of load on this at times.
Stop by and see what we are working on @ www.eddytheb.com
