December 2024
  #21 (permalink)
Old 01-27-2011, 01:43 PM
mikiec's Avatar
Ivory soap has worked for generations. I have never liked the belt dressing products. They seem gummy and sling crap everywhere. At least that is my experience.
  #22 (permalink)
Old 01-27-2011, 01:55 PM
dave from mesa's Avatar
Cobra Make, Engine: FFR from Levy Racing 302 FI w/Edelbrock Performer heads
Nuttin worse than crap slung all over your engine.
dave from mesa
Vietnam Vets may be eligible for medical care and disability compensation. Contact the VA if you have prostate cancer or type 2 diabetes. Finally got around to going to the VA.
  #23 (permalink)
Old 01-27-2011, 02:06 PM
Cobra Make, Engine: Backdraft #90, 351w,Tremec 3550, SB100 SOLD
Are you absolutely sure all your pulleys are in alignment. I had this problem on my Backdraft. I eventually shimmed a pulley slightly and the problem noise went away.
Skip
  #24 (permalink)
Old 01-30-2011, 08:25 PM
Spoooky's Avatar
Cobra Make, Engine: 65' SPF (511 CID) FE 427 Alum Block Shelby /Roush 600hp-625fpt sideoiler
Well, the Ivory soap did the trick...
  #25 (permalink)
Old 01-30-2011, 08:27 PM
Jerry Clayton's Avatar
99 and 44/100 pure anti squeek belt dressing!!!
  #26 (permalink)
Old 01-30-2011, 08:37 PM
Gaz64's Avatar
My 2c.
Pulley alignment is the major issue.
Aftermarket kits are bad in design, who says the components are in the correct order?
Logic says to "pull" on the components with the most horsepower loss first. Obviously tensioner last before returning to the crank.
Aluminium pulleys are worse at gripping than steel.
And another big issue is the belt cannot bottom out on its "V"s.
I pointed this out to Holden engineers with the VE Power steering pulley issue, took them a while to understand.
The belt drives on the "V" flanks only.
Gary
