December 2024
Old 09-27-2013, 06:47 PM
Fitz's Avatar
Cobra Make, Engine: FFR Mk 3 408 530 - 585 T- mustang Dyno at B&R
Default New Tires
Down to 4 whatever on my rear Mich PS2 295/35//18's; not happy with wear but fronts good. Who is suggesting good 4 brand tires. Thinking of going to Nittos; have had Sumos but they all wear so fast? Suggestions and where to get?
Fitz
fitzus1@gmail.com
Old 09-27-2013, 09:15 PM
Get rubber ones.
Glad to help.
Your welcome.
AZ Bob
Old 09-27-2013, 09:31 PM
Fitz's Avatar
Those new rubber less ones you can see through!
Fitz
fitzus1@gmail.com
Old 09-28-2013, 01:54 AM
Cobra Make, Engine: Superformance #522
Nitto NT01s
Old 09-28-2013, 09:34 AM
Karl Bebout's Avatar
I really like my MT street radials and they've lasted years.....oh yea, the car was dead over 4 years...
Wit yo mony, why not go with Avon?
You got rid of that hole in the water where money goes (das boat) might as well boost BOs ecconomy.
Karlos
Old 09-28-2013, 10:29 AM
mikiec's Avatar
While your at it change them over to 15 inch and get those Ghetto wheels off.
Old 09-28-2013, 12:16 PM
Fitz's Avatar
Mickie Mikey - noticed a lot of coupes and others going to 17-18 lately. You should try it... Not getting those Mich PS2's again- way too much $420 at Discount and they don't last any longer then cheap Sumos etc . My front 2 are still really good though?...what to do...
Fitz
fitzus1@gmail.com
Old 09-28-2013, 09:47 PM
RedSnake351's Avatar
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
Red face You don't have to thank me!
Fitz, I've got the answer:
Car, RV, Truck, and Commercial Retread Tires for Sale | Tire Recappers
Ralph
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
Old 09-29-2013, 05:38 AM
GBowman's Avatar
Cobra Make, Engine: BDR #1230/B2 445CI SBF
PS2"s were awful traction wise, if you went with the Nitto NT01 you'll spend about 900 dollars from Discount tire Direct online and get them heat cycled by them. I replaced my PS2's and couldn't believe the difference.
Gary Bowman
Voorhees NJ/Key Largo Fla/Ventnor NJ
Old 09-29-2013, 08:50 AM
bobcowan's Avatar
At that size, your choices are somewhat limited. Nitto only makes 2 tires in that size, the NT01 and the new Invo. Both around $230-250 each.
But, if you use a 284/40-18, you can find other choices. The Nitto 555 is an excellent all around street tire, and costs about $200. I'v been using those for a couple of years, and I really like them. When they wear out, I'll probably get another set.
I have heard good things about about the Goodyear F1 tire. I believe it's a factory tire for a lot of vehicles, like the Corvette and Charger. Somewhat cheaper than the Nitto, at about $170.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 09-29-2013, 10:15 AM
vettestr's Avatar
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Another vote for the Nitto 555 NT. I just had Discount install a set @ $160 a tire out the door. The difference is night and day from the BFG TA's that I took off. Only about 300 miles on the Nitto tire but they are great so far.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 09-29-2013, 11:26 AM
mikiec's Avatar
The BFG TA's are great. They keep you from doing stupid things.
Old 09-29-2013, 01:55 PM
wrogers55's Avatar
Cobra Make, Engine: Backdraft #318, 418 CI, 532 RWHP, Mass Flow Injected, TKO600-Road Race, BMW M3 Suspension, Race Springs (Wouldn't do it again, rough on the street).
+1 for Nitto NT01s.
Discount tire/American tire is a good source and have them heat cycled at the warehouse for $20 each. Wait about a week or 10 days after heat cycling before you really use them hard and they will grip extremely well and last a very long time.
Wayne Rogers in Hideaway, Texas
Old 09-29-2013, 03:09 PM
rpatton3's Avatar
Cobra Make, Engine: Backdraft 874 solid red Roush 427 small block 515 hp
OK, here is a question from Arkansas. Will the 17"'knock off wheels fit a tire changer without messing up wheel? I have a four pound lead hammer and proper pliers.
The wire is here, too. Can my wheels be balanced on regular machine?
All my weights are on inside now.
I could go to Memphis if I have to. Any suggestions for anything even where in Memphis?
There were no atheists in the foxholes.
Old 09-29-2013, 03:53 PM
The answer is yes. But, a couple of subjects crossed here. First, your lead hammer should be 6 lbs and not just any lead hammer. Second, a road-force balance would be best. Third, instead of lots of weights you should rotate your tire on your wheel so it needs the least number of weights. Most any shop can do it. Just needs attention and patience. Finally, if you buy cheap tires they may never be perfectly round.
AZ Bob
