March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
  #41 (permalink)
Old 01-13-2014, 01:18 PM
Danr55's Avatar
Actually it.would not.be perpendicular to either line. It would form.an isosceles.triangle.
Dan in Arizona
CCX3209
  #42 (permalink)
Old 01-13-2014, 01:21 PM
Bernica's Avatar
Senior CC Premier Member
If I followed all of Patrick's advice, I would have twin roll bars, a solid flat tappet cam and live somewhere cold and lonely!
  #43 (permalink)
Old 01-13-2014, 01:57 PM
No, you would be healthier, wealthier, and wiser.... And you know that.
  #44 (permalink)
Old 01-13-2014, 02:09 PM
What if points A B and C were all along the same line and the line goes left to right. Then you move point A to the left (along this line). Think about it.
_____________________
  #45 (permalink)
Old 01-13-2014, 02:16 PM
Bernica's Avatar
Ok, but what if ABC were in space where there is no up/down or left/right?
  #46 (permalink)
Old 01-13-2014, 02:34 PM
Bernica's Avatar
Sorry, that was a stupid question on my part in retrospect.
I can only really relate in construction terms, which I think is what Car Nut was leading to.
"If I have my surveyor's transit over point A, and I'm looking at Joe, who is holding the target at point B, and in between I have Patrick holding target C, which is directly in line with my sight of Joe, then I move my instrument to get back to my direct line of sight with Joe. Now, how much do I tell Joe to move over to get Patrick back in my direct line of sight?" Hey, I'm tryin'!
  #47 (permalink)
Old 01-13-2014, 02:58 PM
Bernica's Avatar
BTW, "Joe" is actually Mike, but he was working a side-job for cash and Patrick was getting pissy because he wasn't allowed to move to get back in the direct-line shot between Mike and I.
  #48 (permalink)
Danr55's Avatar
If you have your transit looking at target B. Target C would be at some point beyond B. When you.move A you change so that line.A B no.longer points directly at.point C.
Dan in Arizona
CCX3209
  #49 (permalink)
Old 01-13-2014, 03:03 PM
Bernica's Avatar
Point taken. Thank you Dan.
  #50 (permalink)
Old 01-13-2014, 04:13 PM
But what if a or b moves along the line towards or away from you.
  #51 (permalink)
Old 01-13-2014, 04:36 PM
Danr55's Avatar
Then the intercept line would get longer or shorter depending on which one moves and which way it goes.
Dan in Arizona
CCX3209
  #52 (permalink)
Old 01-13-2014, 04:50 PM
Everyone is sober, so they all walk a straight line.
  #53 (permalink)
Old 01-13-2014, 05:15 PM
twobjshelbys's Avatar
It's a high school trig problem. Originally ABC were on a line. A' is 1/8' (we assume at a right angle to the original ABC line. If A' is 1/8" along the original ABC line then B does not move. No matter what we need to know the angle of A' vs the original ABC line.
Then the new line is A'C. The problem to be solved is the location of B' (where the new line is A'B'C.
It ought the be a solution for a right angle triangle.
But we need to know the precise location of A' first.
If this is a theoretical problem where all of them are zero dimensioned points there will be an answer. if this is a practical problem then just overdrill the f'n hole at B' and get over it. A bolt and washer washer will cover it.
If you need an engineer stamped drawing find a PE.
Tony
CSX4005LA
  #54 (permalink)
Old 01-13-2014, 08:00 PM
Bernica's Avatar
From me? Or from a stated point?? That wouldn't matter, would it? Because AB are a constant straight line. They could be in motion and will always retain a straight line.
And please don't tell me I have to factor in the curvature of the earth!
I'm just a dumb-ass carpenter, but I'll keep playing
  #55 (permalink)
Old 01-13-2014, 09:41 PM
Default The answer is 0"
Originally Posted by mikiec View Post
Point A to Point B = 26 inches. Point C is a fixed point in the distance.
If I move point A 1/8" to the left. How much do I have to move point B to maintain a straight line to point C?
The answer is 0".
It’s a trick question….sort of. The trick is in how you look at it.
You have to look at it as if line ABC goes from left to right. Originally, it’s 26” from A to B, and we’ll say X” from B to C, with point C being “in the distance” to the right. Something like this:
A_________________B_________________________C
After moving point A 1/8” to the left, they are all still in that same straight line ABC going from left to right. It's just that now it is 26 1/8” between A and B, and still X" between B and C. No point ever moved out of this line. Now it looks something like this (not to scale...and my attempt at a depiction just shifted B and C to the right, but you get the picture):
A_______________________B_________________________ C
If a man does not keep pace with his companions, perhaps it is because he hears a different rumble. Let him step to the sidepipes which he hears, however measured or far away. - H.D. Thoreau...if he had owned a Cobra
  #56 (permalink)
Old 01-14-2014, 05:08 AM
Danr55's Avatar
it could be interpreted that way but the implication is that A moved off the line A B C to the left and created lines A C and B C. The question is asked about the length of the intercept. If there is no intercept, it becomes an invalid question and I've known Mikie long enough to realize he would not ask invalid questions.
Please Mikie, say it isn't so!
Dan in Arizona
CCX3209
  #57 (permalink)
Old 01-14-2014, 05:23 AM
mikiec's Avatar
It ain't so.
When A is moved, How far should B move, in the same direction as A, to maintain a straight line to C which does not move.
  #58 (permalink)
Old 01-14-2014, 06:22 AM
Cobra Make, Engine: FFR MK-I, 302, 780 Pro-Systems custom double pumper, 425HP
If I were a moderator I would take this post off line.
Mesa Mike
  #59 (permalink)
Old 01-14-2014, 06:25 AM
At what angle from the straight line did A move away from its original point? You appear to have made an assumption that it is 90 degrees, where the "question" does not specify.
  #60 (permalink)
Old 01-14-2014, 08:15 AM
Danr55's Avatar
The question indicates that the point A moved 1/8" from line A B C. In order to be 1/8" from the line, it must be in a perpendicular direction. If you move 1/8" in anything other than 90 degrees direction , the resultant distance from line A B C to the relocated point A will be less than 1/8".
Dan in Arizona
CCX3209
Display Modes
