1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
02-23-2007, 10:36 PM
AZ
Cobra Make, Engine: Cobra-less for now..
Originally Posted by steven566
I drove the car to work a couple of days this week, and it wasn't too bad in the morning, nothing a jacket couldn't take care of.
Well done!
Thank goodness you didn't listen to the old ladies!
Wait until August.. you will want to sit in an ice chest to drive..
It's under a big W, a big W see?
02-24-2007, 01:38 AM
Club Cobra Member
Fra
Cobra Make, Engine: Paint:Metalflakes Royal and Abalone stripes registered in France in 1973. Engine: Ford Shelby aluminium block, 482; two 4-barrels 600cfm Holley; Edelbrock Performer Aluminium heads,,fluid damper,4-speeds Aluminium Toploader (short), 2.88rear
No heater for me. Even in winter, adequate clothes and a fur helmet are really sufficient. I drive hundred of miles in winter without feeling chilled. My feet are always warm!!!The only time I had a small inconvenience was driving in freezing fog: my windshield was obscured by ice and I had to remove the frost periodically from my windshield with one hand (I have no top on my Cobra).
Queenie
02-24-2007, 06:40 AM
oh
Cobra Make, Engine: BDR #260 w/ 347 stroker, Canfield 195 cc heads, prosystems carb on a VicJr, Comp roller cam
Originally Posted by ROUSHAC
Got the Bug,
No, I did them myself, but I did have to remove the seats to get the pad into the seat backs.
My battery is in the trunk, so I ran the wiring down low through the rear bulkhead and placed the switches on the rear bulkhead on either side of the battery cut-off switch.
A lot depends on how easy it is to get the pads into the seats and then get your seats back together. On my BDR it was easy. On an others like an SPF, I'm not sure how easy doing a neat job on the seats will be.
Cheers!
Dave
Dave,
Can you provide more details on what is required to install the heating pad in the BRB seat? Any special tools required? I've got one and thinking about heated seat.
Thanks in advance for your feebback.
BDR#260...21.6K miles logged as of 4/2018
www.motorheadsohio.com We are an engine machine shop, specializing in crankshafts!
47 years of doing business an going strong! stop on by for a personal tour of the shop
02-24-2007, 06:54 AM
NJ
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
It comes in handy on crisp fall nights to keep the windshield from fogging up
and you get some heat but without a top it's not exactly toasty!
02-24-2007, 07:48 AM
PA
Heat is really nice to have here in the North East.
Crank up the heat and don my "Elmer Fudd" hat and HIT IT!!!
02-24-2007, 02:39 PM
NY
Originally Posted by tamanaco
Dave,
tamanaco,
The seat bottom is a snap. Take the cushion out. Remove the staples at the rear of the seat and push the pad in with you hand to make sure it lays flat under the foam. Replace with new staples.
The back is a bit tougher. The leather is glued in place for about 3" along the bottom. I was able to loosen a part of the glued area with a very flat fish filleting knife by carefully working between the glue and the fiberglass molded seat - this took longer than everything else combined. I created a hole big enough to get my hand and arm into the seat back behind the foam. Unfortunately, unless you are double jointed, you then have to remove the seats from the car to be able to insert the pad into the seat back and put it in place and get it laying flat under the foam pad. Once that is done, reglue the area you loosened with Gorilla Glue.
On each seat, drill a hole in the bottom of the seat at the angle made betwwn the bottom and back through the fiberglass and another low down through the rear bulkhead to run the wires to the controller and to the battery in the trunk.
I drilled the holes for the controllers through the rear bulkhead a couple of inches to each side of the battery cutoff switch.
Set the seats back in the car and run the wiring through the holes to the trunk. Install the controllers in their holes. Bolt the seat back down. Hook up to the battery. You are done.
I have been thinking about how to rewire it so that when I turn the car off the seats won't continue to warm the car and drain the battery, if I forget to turn the battery kill switch off. I just know that I will forget sooner or later, if I don't do that, but it's too cold to work on the car for a while yet.
Not a bad job at all. The instruction sheets that came with the seat heaters were pretty well done.
Hope this helps!
Cheers!
Dave
Dave
02-24-2007, 02:48 PM
NY
JBCOBRA,
Thanks for the idea of the Elmer Fudd hat!
I got one after seeing the post of you in one. It works like a charm for the one place the seat heaters don't help.
See you at the Zippo Vintage Races next Fall at the Glen again hopefully. Maybe the policeman won't wave me onto the wrong road again on the way back to town from the track. I don't want to have to worry about all those crazy folks in their MG's trying to keep up this year. That was funny.
Did I leave enough tire smoke as you requested when I left the B&B to head home?
Cheers!
Dave
Dave
02-24-2007, 03:01 PM
Ont
Cobra Make, Engine: Shelby CSX 4995, Keith Craft built 427 SO
I live in the snowy north, my Classic Roadster does have a heater. I have yet to use it. If it's that cold out, I'm not interested! Go ahead, call me a wussy!
"The 427 Cobra is easily the highest performance car ever sold for street use. A decent 427 - not the worst, not the best, will go from zero to 100 mph and back down again to zero in less than 14 seconds. All thing considered, you can put together a pretty good argument that the 427 Cobra is the ultimate performance car, judged on any basis you want to name." Taken from; Corvette, The Sensuous American
02-24-2007, 06:08 PM
sc
Cobra Make, Engine: SPF #2457, Sunset Red/Titanium Stripes,460FR, SCJA, TKO 600
Go to www.gerbing.com and get a 12v heated vest that plugs in to 12v system. This is what motorcyclists wear. Will keep you plenty warm.
"The Cobra is a 40 year old design that moves people like no other".
02-25-2007, 06:24 AM
PA
Cheers!
Dave
YES, that was great! Nothing like the smell of burning rubber in the morning!!! LOL. Watkins Glen is the BEST.
I will drive my car without the top (and the heat cranking) to about 38 degrees. That is cold enough for me and the car. The engine can't even get warm enough below that (even with the oil cooler disconnected) and I start praying for Red traffic lights to warm up a little.
JB
02-26-2007, 06:06 PM
ca
Cobra Make, Engine: superperformance, 427 side oiler
NO. Immediate reaction without reading this thread.
... and when you start your Cobra its inner voice shouts at you "You f***ing assh*le, this time I'm going to kill you."
02-26-2007, 06:15 PM
PA
ez, and your point would be?
02-26-2007, 06:25 PM
Banned
CA
GOD BLESS YOU! This is the best idea on this thread yet! Cheaper and lots less hassle than ripping out the seats and having warmers installed. Thank you!
-Dean
