1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
07-29-2009, 10:14 PM
GA
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Originally Posted by bakbutler
Arthur
rear height at frame is 7" Front height at frame is 6"
ground to fender lip
rear 28 1/2
front 26 1/2
I can probably drop the rear another 1/2" frame to floor, but that would be about it.
Hope this helps
Leo
PS fast cars ifs will probably be my next upgrade.
How do you like the stance & height as you've set it up?
I'm setting up my Cobra to have 5" ground to frame clearance, front & back. I hope I'm not going too low. I can always adjust it up, but shimming the half-shafts to get rear wheel camber correct can be a pain. I only want to do this once.
Fast Cars is a really great system Ted is a great guy. I believe that Unique Cobra IFS will fit the Butler too, but Fast Cars is a 2 hour drive for me, so I could check it out easily. I looked at all my receipts for putting together my modified MGB front end that I had already installed on my car and I spent about $3,000.00 and that was 15 years ago. I never put a mile on MGB IFS. I was never happy with having such a basic setup on the Cobra. I think it's a total mismatch for the super rear IFS. Was happy to be rid of it.
07-30-2009, 09:16 AM
ca
Cobra Make, Engine: Butler, 351W
I like the stance and height very much, although this is a personal thing. Although these tires are not track tires, hold very well. Previously I was running BFG 295-50-15 on the rear and was about 3/4 inch lower. Will try to post a picture.
07-30-2009, 05:13 PM
TX
Cobra Make, Engine: Butler...488" hi-rise, dry-sump FE s/o w/stacks
Arthur,
My car is 4.5" frame to ground, front and rear. My rear tires are 335x30x17". No rubbing. I like the low look and have not had any ground clearance issues as yet.
Russ
08-02-2009, 10:40 PM
GA
4 1/2"! Go-Kart style. You must have good roads too.
Russ, How are you enjoying your Fast cars IFS? I've made little progress on my build. I had a diving accident in Australia, got a brain hemorrhage and have spent four months recovering. Almost ready to get back to work on it.
08-17-2009, 08:07 PM
TX
Arthur,
Sorry to hear about your accident...glad you are OK.
I love the Fast Cars....have only driven on the street. It tracks nicely, turns much easier....I am very pleased.
I answered your post on the side curtains. Looking forward to seeing what you come up with.
Russ
