November 2024
  #21 (permalink)
Old 02-26-2010, 11:28 PM
boxhead's Avatar
Yes you have them connected correctly.
You have probably tripped the warning light switch, you should remove the white switch on the side of the master cylinder.
This switch has a small pin that slides into the master cylinder piston, when it travels too far the pin locks into the piston and limits its travel.
So try removing that switch, pump the pedal a couple of times and refit the switch.
Cruising in 5th
  #22 (permalink)
Old 02-27-2010, 07:12 PM
Thanks for the suggestion Boxhead. I tried your idea with the still the same result (I even left the switch out). It seems that it's the front circuits that are the problem.
Peter
  #23 (permalink)
Old 02-27-2010, 10:02 PM
Tenrocca's Avatar
Peter - when I did mine I was having problems bleeding the fronts - not alot coming out. Took the bleed screw all the way out the the outlet was a gunked up - cleaned them out with a small drill bit and it did the trick. Probably not it but worth looking at.
