February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 07-20-2010, 04:04 AM
Cobra Make, Engine: Python
Default Jaguar/ Dana 44 Drive shafts...... Help !
Can anyone out there tell me if you can get 30 spline drive shafts that will slip into a series 1 Jaguar lsd IRS with a 3;54 ratio. I want to put a truetrac locker or similar helical locker in, replacing the standard lsd arrangement. I have 19 spline drive shafts in which I assume is standard.
There may be some shops that offer aftermarket shafts ( here or USA) that will suit the old Salisbury !!
There are no Eaton or Detroit truetrac products in a 19 spline that I can tell hence this call for help.
Chris L
Old 07-20-2010, 06:45 AM
I should mention that these drive shafts are the INNER units.......the ones that exit each side of the diff, NOT the units that are splined in the cast hubs to the wheels. Im basically chasinig a 30 spline conversion so I can open up my options to a locking centre.
Chris
Old 07-21-2010, 12:11 AM
Chris, send an email to these fellas: http://www.cwiinc.com/index.html
Old 07-21-2010, 12:51 AM
Cobra Make, Engine: AC Adelaide Cobra - 351w & 4-Spd Toploader C/R - "Construction Underway!"
Originally Posted by Chris L View Post
Hello to everyone;
Can someone please point me in a direction where I may be able to buy some 30 spline drive shafts to suit a Jaguar / Dana 44 IRS to enable a truetrac or similar locker to be fitted to the rear of my Cobra. I have a series 1 Salisbury Jaguar lsd diff and it has a 19 spline set up and a 3;54 ratio. I only wish to change the spline teeth and diameter/bearings if thats possible.
Maybe there is a custom shop that may specialise in a request like this, need some answers in a hurry.......thanks in advance.
Chris L
Australia
Hi Chris,
Can I ask why you are looking at upgrading to 30 spline axles? Are you drag racing your car or is it a Track build. I notice that a lot of the Guys here in Australia are running 19 spline axles with reasonably high HP. At 1100 or so Kilos in weight you would have to "treating her rough" to break anything.
Having said that... have a look here - http://www.reiderracing.com/
Regards
Roy P.
Old 07-21-2010, 02:12 AM
tomcat racing's Avatar
Cobra Make, Engine: Some kind of FORD thingy, with several pis tins, twin chain driven SUs feeding a Y block, apparently.
Originally Posted by RoyTheBoy View Post
Hi Chris,
Regards
Roy P.
read his second thread, thats why, ive got basically the same setup and never had an axle problem under hard launches but have expired a diff. please keep us posted on what your final setup will be.
Nuts,,, Bolts,,, and 2 smoking barrels.
Old 07-21-2010, 03:44 AM
Fair enough Fellas, I did not realise how rare the request was. The left side shafts spline is slightly damaged, its probably ok but whilst everything is apart, its something I dont want to go through again. I figured swapping to 30 spline would open up a wide range of locker options for the centre.
It seems I will stick with the 19 spline, get them re-done and look at a detroit soft locker to suit. The car is not a high hp set up at present , but that will most likely change as we start on a new motor. I do intend to work it hard at some track days. The arse will have to be solid as it will be dealing with around 600 hp courtesy of a stroked Dart block with Yates heads and cross ram injection. Just trying to figure out how to pay for it all !!.
Chris
Old 07-21-2010, 07:13 AM
cobrarkc's Avatar
Cobra Make, Engine: Contemporary 482 all aluminum Tunnelport Self built and owned since 1980 frame#0000017 and owner of frame CCX 33961 looking for an FIA body to go with it
Default Cwi
Mike @ CWI has closed up this portion of his business
Cobrarich
Old 07-21-2010, 01:56 PM
Hi Chris,
Not sure if you've look at the following URL but they have a couple of options for 19 spline diffs (DANA 44s) that might be of use. Be careful though, as far as I can undertstand you'll need different (possibly custom) bearings and stuff (crown wheel bolt sizes too if I recall) as I think there are slight differences between the jag and dana specs. Also if you avoid the crown wheel bolt issue by buying dana gears I think the pinion bearing is a different size too but again I've only had a cursory look a couple of months back, others may have more/better info on what bolts in and what doesn't.
http://www.ringpinion.com/PartsList....er+D44&CatID=7
