questions
- » Blogs
- » Image Gallery
million posts!
November 2024
1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
01-06-2011, 02:52 AM
NSW
NCOP revised.
Advertising
01-06-2011, 04:34 AM
QLD
Seems a comprehensive and up-to-date resource/data base.
I did notice the now allowable engine capacity relationship to vehicle mass:
All vehicles originally weighing more than 1100 kg.
Original mass (kg) x 5.0 = max. capacity in cc’s
Original mass (kg) x 3.0 = max. capacity in cc’s (turbo and supercharged).
Does this rule out some of the larger motors in Cobras?
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
01-07-2011, 02:16 AM
NSW
A few More surprises. What else can you bureaucrats think up?
Originally Posted by Zedn
Looks like I will have a few MORE hoops to jump through.
And I thought 2011 was going to be a good year.
Wasn't I mistaken.
Baz
01-07-2011, 04:48 AM
NSW
ICV checklist hasnt changed and is out of date.
Still has 700mm for seats and still has glare reduction in field of view.
power to weight ratio is a worry. I hear lead makes a great undercarpet insulator
01-07-2011, 02:54 PM
[b]Unfortunately, version 2 of VSB 14 is bad news, the brake test is much more stringent (section LG) and will need to be done on a test track. Building ICV under version 2 is going to be more challenging than in the past, hence the cost will be higher as well.
Part of the email i got from my engineer.
Stan
01-07-2011, 03:29 PM
Qld
Cobra Make, Engine: Evans kit, 6 litre, 6 speed, Jag F/R,
Since we have little cars with big brakes has anyone encountered trouble complying? Except for those who couldn't be bothered to adjust the handbrake "correctly"?
NCOP QUOTE "A simplified brake test procedure has been developed for demonstrating compliance with the
brake performance requirements of ADR 31/01 to enable the certification of the brake system
and brake modifications under Code LG1."
Big car brakes are a bonus "For tests 2, 4 and 5 ICVs may be tested at 100 km/hr if the mass of the vehicle to be
tested is less than the mass of the vehicle from which its brake system was sourced
(e.g. Clubman type vehicles)."
Table LG5 Test Sequence and Conditions for ADR 31/01 Abridged Brake Test has the procedures, they might take a while but really, who wants substandard brakes? I just fitted up a new XY PBR booster as it is a bit punchier than the Girly one it had (and on it they modified it wrong so the reaction valve wouldn't operate). With Jag brakes, XY booster and master I feel confident.
In this day and age testing time is money tho, so I can appreciate the statement from the engineer "hence the cost will be higher as well"
Missed my Cobra budget by thaaaat much.
Ya get that on big jobs.
01-07-2011, 03:43 PM
Qld
Speaking of brakes,
It is now written.
2.7.2 Protection
Caliper pistons must be fitted with dust seals.
This removes the vague wording previous about being suitable durability.
01-07-2011, 04:54 PM
QLD
How do others interpret the weight/engine capacity ruling?
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
01-07-2011, 06:15 PM
WA
Cobra Make, Engine: FFR Mk4 Roadster, LS3, TR6060, 8 3/4"
IF I have build approval dated prior to 01Jan2011, do I build to the previous regs?
Thx
01-07-2011, 06:18 PM
NSW
Stan,
The brake test procedure has been in force in NSW since October and before that there was a very similar test also required.
This is a problem for NSW people because there is limited tracks available and basically means paying an engineer for 6hours travel time to get to goulburn from Sydney and then the cost of the test and track hire. My engineer had a cobra that failed and it cost him $3000. The test will still have to be redone!
Outwest,
The abridged brake test will still require all of our cars to be done at 160kph. The note about heavier doner cars is not relevant unless you are using the complete system from a doner. Using calipers and a different master cylinder and pedals requires full speed test.
The problem with the test is spinning out. The car will stop, it just needs to remain straight and not lock up the back wheels.
Merv,
I think the power to weight ratio is not relevant to us. In NCOP10 there is a statement about ICVs being made by the manufacturere and hence not having to comply with the modification rules of VSB14 unless modifying factory doner parts. I think that the power to weight ration is intented for engine transplants in cars not designed for such a large engine. If a cobra is build with that engine and all testing is carried out with that engine there shouldnt be a problem.
Liam
01-07-2011, 06:31 PM
Qld
"The abridged brake test will still require all of our cars to be done at 160kph. The note about heavier doner cars is not relevant unless you are using the complete system from a doner. Using calipers and a different master cylinder and pedals requires full speed test."
Hmmm, I think I'll let the engineer do the driving in that case.
I stand behind all my brake work, it's safer than in front.
