questions
- » Blogs
- » Image Gallery
million posts!
December 2024
1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
01-20-2011, 04:30 PM
Vic
Cobra Make, Engine: Harrison, VE L98 + T56
Air bleed pipe Gen 4
On the front on the heads there is a small diameter steel pipe to bleed the air out of the heads, which goes to the header tank (on my commodore). I have copied this setup on my L98, there seems to be quite a flow of coolant thru this pipe, which makes the tank quite hot, whereas I thought is was more of a reservoir,
Does anyone know if there should be some sort of restrictor on the flow, so that it keeps flow to a minimum? Thanks
Life is what happens to you while you're busy making other plans...JWL
Advertising
01-20-2011, 05:22 PM
VIC
Hi Peter. I have an urestricted rubber hose from the bleeder to my header tank but I haven't run the car for more than 5 mins at idle, so it's hard to say. Have you actually measured the temp of the header tank and compared it to the Commodore? Could it be that you have a metal header tank in the Cobra (better conductor) and plastic in the Commodore, hence the temp difference? Or is the Cobra running hot, fan temps wrong...?
01-20-2011, 07:57 PM
NT
Pretty sure there is no restrictor.
Cruising in 5th
01-22-2011, 12:45 AM
vic
Yep, no restrictor, the small diameter pipe is the restriction.
You don't need to have it going through the throttle body however. This is just for quick warm up in frozen conditions, and probably doesnt help with air temps!
Powered by Cu
01-22-2011, 01:03 AM
Vic
throttle body bypass mod of water is a common mod in the LSx world
Ben in AU
01-22-2011, 03:02 AM
Vic
Thanks Guys
01-22-2011, 04:13 AM
NSW
My tank is inline between engine and rad, the steam pipe feeds into that, but it constantly has coolant running through it, so not an issue with thus setup. Hope I explained that ok.
