I think they will fit but you'll need to use a filter box similar to Phil Mizzi. This would probably be a good thing because every time you open the bonnet the trumpets would be fully exposed!
before u buy any aftermarket webber lookalike throttlebodies
make sure u physically look at them in your hands
ive seen afew over the past years and would have resevations on using em on my car if i had one that needed em
the final finish is sort of ok not perfect
also very fiddly to set up
i had to fit a tripple setup to a holden 6 motor last year and fkt round so much i just got sick of them
getting fuel lines to line up with injectors and linkages was big pain in the butt
id go for the 8 single throttles u find on hot rods in the states
but just ask many questions and maybe even go look at some fitted to cars as i have not seen many good looking and user freindly kits made in australia
Thanks Jim ,I will take your advice.
They look great in the pics but fitting them and getting them to work may not be worth the money or trouble.
Thanks again Paul
