December 2024
Old 04-06-2011, 07:08 PM
leroy17's Avatar
Default Anyone using 255 45 17 front tires
Hi guys,
I am looking for new front tires, was looking at 245 45 17 however thinking about 255 45 17. Rears are a 285 40 17 which has a similar rolling diameter to a 255 45 17, the 245 45 are just a bit smaller however visually would provide that slightly raked look.
I cant seem to find any images of 255 45 17's to see if they look right or wrong.
So, any feedback appreciated.
Cheers.
Old 04-06-2011, 07:57 PM
Krait's Avatar
I've got 245/45/17's on the front and 315/35/17's on the rear.
Geoff
Old 04-06-2011, 09:35 PM
wrogers55's Avatar
Cobra Make, Engine: Backdraft #318, 418 CI, 532 RWHP, Mass Flow Injected, TKO600-Road Race, BMW M3 Suspension, Race Springs (Wouldn't do it again, rough on the street).
Me too. On a Backdraft. Nitto NT01s, looks great and stick like fungus.
Wayne Rogers in Hideaway, Texas
Old 04-06-2011, 10:05 PM
jdean's Avatar
I have 255s on the front and 315s on the rear.
6th generation Texan....
Old 04-09-2011, 04:33 AM
AC-460's Avatar
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
I have 315 x 17 on the front and 335 x 17 on the rear
Old 04-09-2011, 04:39 AM
AC-460's Avatar
Only 1000mm between front tyres and 1100 between the rears<img src="http://www.clubcobra.com/photopost/data/500/DCP_0029.JPG" />
Old 04-09-2011, 06:23 AM
Zedn's Avatar
315 on the front! How the steering? Do you have power steering?
Old 04-09-2011, 06:51 PM
AC-460's Avatar
Neutral
No power steering.....Suprisingly the steering is easy...its only 550kg on the front
rims are zero offset and tend to roll not screw...
Old 04-10-2011, 04:59 PM
leroy17's Avatar
315s on the front, looking through the pix and it sits nice.
Given the choices I will be going to a 245 45 which will sit well with a 315 35 rear later.
Appreciate the responses and AC-460, that looks awesome.
Cheers.
