November 2024
Like Tree1Likes
Old 09-13-2011, 02:26 AM
Merv and Sharon's Avatar
Default Gas struts
I have the common 'rod' bonnet strut, in my case one from Snakebite. I have been thinking about gas struts and I am aware of some of the potential problems with these. Is there a suggested type, model, pressure of strut that is appropriate?
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 09-13-2011, 04:21 AM
boxhead's Avatar
Neutral
The best I have seen dont go onto the bonnet, but instead work off the hinge (alot stronger).
Not sure what the hinge setup is on the Harrison?
Cruising in 5th
Old 09-13-2011, 04:55 AM
That would get around the problem of deformation of the bonnet edge. Harrisons have the (usual?) curved hinges.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 09-13-2011, 05:16 AM
OZCOBRA's Avatar
Thumbs up
Merv. I'd even join the 2 Hinges and run 2 smaller struts off each side of a chassis mounted base plate,there are some great little struts about.
Old 09-13-2011, 05:20 AM
Thanks OZ. I think I saw something in a photo a couple of years ago like that ... not sure where.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 09-13-2011, 12:34 PM
Krait's Avatar
Merv,
I think Wazza used:
Struts-R-Us
3/29 Ferry St
4211 Nerang QLD
Phone: (07) 5596 0633
There was a thread awhile back on this topic.
Geoff
Old 09-13-2011, 07:47 PM
Thanks Geoff. I am interested in any photos of how others have done this and what strut they used and how it was attached. There was a thread in 2004 but not much in that.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 09-14-2011, 02:03 AM
I did see in PhilM's Nationals post his trunk struts:
Any like this for bonnets?
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 09-14-2011, 03:09 AM
Outwest34au's Avatar
Cobra Make, Engine: Evans kit, 6 litre, 6 speed, Jag F/R,
Any SuperCheapAuto store can order what you need from Struts Australia. Just need to know extended length, closed length, desired shaft diameter and the force required in Nm.
I recently ordered some through them (for a customer) for a door on a JCB backhoe, it was quick and easy and they came in about $28 each from memorex, way way cheaper than genuine.
Missed my Cobra budget by thaaaat much.
Ya get that on big jobs.
Old 09-14-2011, 04:13 AM
Thanks - will check that out. I am also interested in what the required Nm might be and how the leverage is best placed - for example, on the hinge or on the bonnet lid itself.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 09-14-2011, 05:39 AM
Modena's Avatar
...that is the problem I think. Go out to your daily driver (or Cobra), lift the bonnet by hand, and tell me what Nm was required ?
Ben in AU
Old 09-14-2011, 04:08 PM
Towmaster's Avatar
Default gas struts
Merv,
Did you see mine on the weekend at the breakfast? Stainless gas struts made to suit my application from a guy at Capalaba.
Gas Strut Marine Stainless Steel Gas Struts designed specifically for the marine industry - Stainless steel gas struts, Stainless steel gas stays, Marine gas struts, Marine gas stays, Electrical actuators, Linear actuators, TV Lifts
He did mine and Wayne Proctors struts, excellent quality stuff, can get them any length, he can de-gas and re-gas them.
Old 09-14-2011, 05:24 PM
That looks great Ash. The Harrison does not have that upper rail as does the DRB but there may be an alternative. Will check it out.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 09-14-2011, 09:13 PM
gjkrv8's Avatar
Hi Merv,
I have them on my boot and bonnet.
The boot is similar to Phil's setup.
The bonnet is pictured below (from my Gallery)
I am happy to see what KN they are if you like.
Rgds
gregg
Old 09-14-2011, 10:04 PM
That is neat and seems to look like it would work on the Harrison. If you could check the extended, compressed length and the pressure Gregg, that would help. My hinges are the round tube ones and would need a different attachment, however. With the leverage at that point it would need considerable pressure.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 09-15-2011, 12:21 AM
renovationinnov's Avatar
Cobra Make, Engine: venom motorsports /ls1 auto
Talking
merv
just showed the guy who does all my gas struts for tool boxes & trailer lids he said it was easy to adapt any strut to your purpose [ he would make a bolt on bracket to fit onto your arms 1/3 down from the lid [bonnet ] then hang a plumb bob down to the chassic when the bonnet was at full open ', place a chalk mark close the bonnet chalk mark the chassic , reopen the bonnet & centre between the 2 marks is your mounting point for your bottom mount
then measure the distance from that to your fullopen hinge mark & go to caravan sales & order that lenth [if you can weight the bonnet you can get the correct struts for that weight] if not you can buy a strut & have it regassed to suit the weight
hope this helps
rob
Rog246 likes this.
not all your babies are your children
Last edited by renovationinnov; 09-15-2011 at 12:27 AM.. Reason: just didnt finish/ cant spell
Old 09-15-2011, 12:30 AM
Mando's Avatar
The setup on Towmaster,s car looks great. It nearly makes me want to get the tool kit out! "nearly".
Regards.
Mando
Old 09-15-2011, 05:48 AM
Thanks Rob. I will have a think about that process (think I have got it ... ) on the weekend. I am keener on having the struts on the hinge if possible to keep them out of the way.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 09-15-2011, 11:51 PM
07cob's Avatar
Originally Posted by renovationinnov View Post
make a bolt on bracket to fit onto your arms 1/3 down from the lid [bonnet ] then hang a plumb bob down to the chassic when the bonnet was at full open ', place a chalk mark close the bonnet chalk mark the chassic , reopen the bonnet & centre between the 2 marks is your mounting point for your bottom mount then measure the distance from that to your fullopen hinge mark & go to caravan sales & order that lenth [if you can weight the bonnet you can get the correct struts for that weight] if not you can buy a strut & have it regassed to suit the weight
hope this helps
rob
Rob, this is gold! Working out locations for these struts can be a lot of trial and even more error.
Merv, a bit late for you but here is the setup I have for attaching my struts to the bonnet. Al bracket pinned to the underside of the bonnet. All glassed together and painted. My struts are from a fibreglass canopy.
Geof
Old 09-16-2011, 01:41 AM
Thanks Geof. Your success is what motivated me. I am still not sure if I will go for struts on the bonnet edge or on the hinge itself. The mechanics can be complex!
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
