March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
Like Tree497Likes
  #481 (permalink)
Old 09-21-2014, 02:36 AM
Cobra Make, Engine: CR Cobra 3169
Very nice stuff. I like the heaters. Where did you get those.
Just a offbeat question, with all that aluminium and fibreglass, will you have trouble with the sensors at the traffic lights not picking up the car?
JD
  #482 (permalink)
Old 09-21-2014, 02:42 AM
jcraigau's Avatar
Cobra Make, Engine: G-Force Mk1, LS1, T56, Jag S3 suspension
Those headers on the LSA look like a tight fit!
  #483 (permalink)
Old 09-21-2014, 03:07 AM
400TT's Avatar
Originally Posted by Tenrocca View Post
Hi brad, I was asking about john whites new car.....
Can't wait to see both of them in 2 weeks
John's car is a street car, going through the rego process at the moment, but won't be street registered for the Nationals. That's if he decides to take it, it still needs some work done and hasn't been driven in anger yet.
They are the optional big HP headers we do for the PACE 427. Running off a couple of sets for customers. They are 1 7/8" primaries with high flow tube routing. Perfect for an LSA where you want to get a bit extra out of it. We use the same headers for underbody system and side pipes.
All our headers feature bolt up individual 4 pipe custom flange. So means the 4 primary pipes are kept separate throughout the flange so can be used for side pipes or for underbody system. Our underbody system runs out in the same direction as side pipes.
Also means you can swap relatively quickly between side pipes and underbody system, just unbolt the front connecting tube for underbody system and bolt on the side pipes. Underbody for street use, side pipes for track use etc.
www.absolutepace.com
  #484 (permalink)
Old 09-21-2014, 03:17 AM
750hp's Avatar
Heaters/Headers
I wonder if the question was about these:
mando s likes this.
Craig
  #485 (permalink)
Old 09-21-2014, 03:18 AM
Modena's Avatar
uh I think he said "heaters", not "headers"
Ben in AU
  #486 (permalink)
Old 09-21-2014, 03:50 AM
Laner's Avatar
Cobra Make, Engine: Pace 427sc 351w with TKO600.
Demisters :-)
"Life is hard, it's harder if you're stupid"
  #487 (permalink)
Old 09-21-2014, 05:48 AM
400TT's Avatar
Oops, I inserted the wrong quote and forgot to reply to the heater one, my reply above is now correct. Heater reply below.
The demisters are a standard part of PACE 427 kit. Uses a plastic moulded ducted housing (made by us) and electric demister motors. Very effective as they are fast acting. They provide both cool and heated air.
If you are chasing actual heaters, I have not found heaters to be effective unless you have the roof on with closed windows. We recommend customers configure their seats so they are heated as that is much more effective in my opinion.
We do supply a forced fresh/cold air system with the kit as well. Provides ducted fresh air separately into both drivers and passenger footwell areas. Airflow is controlled by concealed pull vents. Air ducts are pressure fed from main air intake on front of the body. We don't use the brake ducts for fresh air as we find these don't provide the amount of air required. We instead supply plastic ducts to make the brake ducts functional for their original purpose. I believe the brake ducts also look far better if they are actually connected and not just sitting their empty.
  #488 (permalink)
Old 09-21-2014, 06:46 PM
albanycobra's Avatar
Craig
Can buy a few of your demisters? I need 4....
  #489 (permalink)
Old 09-22-2014, 02:04 AM
So they are able to pass inspection?
Your right , a heater in a Cobra is as useful as a ashtray on a motorbike.
How much do these demisters cost?
I like the heated seats idea, or plug in jackets. I have a freezer suit that they use in freezer when I used to fly Gyrocopters.
But you look like the Michelin man.
JD
  #490 (permalink)
Old 09-22-2014, 06:26 AM
Wazza's Avatar
Have to disagree there....
LOVE having a heater in the Cobra.....ducted to blow hot air around the shin area,and it then sort of "washes" warm air upwards, and over you ...works brilliantly.
The wife said it's the best idea we ever had.
Comes out of these chrome "sink" thingys.....
Warren
guye likes this.
  #491 (permalink)
Old 09-23-2014, 12:59 AM
Wazza is it just my eyes or do I see that an LED has blown in that pic.......
  #492 (permalink)
Old 09-23-2014, 01:25 AM
Wazza's Avatar
It's your eyes !!
The light shines out through a rectangular slot,and shines down on the "Cobra emblem" in the floor mat.
Funnily enough, that first photo was taken when we were building the car, but.....that LED failed only last week...and I put a new one in yesterday....
Spooky Huh !?
  #493 (permalink)
Old 09-23-2014, 07:10 PM
Cobra Make, Engine: FFR MK IV/Coyote/PS/PB/ABS/AC
JD
Or a 12V plug-in blanket; my wife loves it.
  #494 (permalink)
Old 09-24-2014, 01:15 AM
Cobra Make, Engine: Absolute Pace 427 SC
Default Light Polish
Originally Posted by sambo View Post
Ahem... the "standard gel coat" doesn't look all shiny. It's more than a few extra bob for that lovely finish if I'm not mistaken - based on the options list that was floating around at Shelbyfest. Not to detract from all the great work, just saying...
Here are some photos AFTER a light buff.
If its not shiny enough for you Sambo then I will use some McGuires polish on it just for you
Cheers All
See you at the Nationals
Brad
deano59, mate, spookypt and 8 others like this.
There is nothing better than a cold beer
  #495 (permalink)
Old 09-24-2014, 05:12 AM
400TT's Avatar
Brad, thought it was time to get Pete to give it a quick polish for you to take out the marks and scratches incurred during the build.
See what happens when you are not at the workshop for a day...
Enjoy.
  #496 (permalink)
Old 09-24-2014, 05:49 AM
sambo's Avatar
Looks great Brad. Would you say it's a better finish than a 10 grand paint job?
"A spectacularly fast car in a grand if dated tradition."
  #497 (permalink)
Old 09-24-2014, 05:52 AM
Wazza's Avatar
What an odd question!
deano59 and Paintwerks like this.
  #498 (permalink)
Old 09-24-2014, 06:00 AM
Cobra Make, Engine: absolute pace chassis #50 L98 & 6 speed auto
when ya doing 80 ks a hr down the highway do you think anyone will say gee I reckon it would look better with paint than a gelcoat colour ? .
the finish on these cars seem to bother you some what sambo for reasons only known to you . but the best part is if brad for example wanted to change colour im sure it wouldn't cost him anywhere near 10g to paint it as the body would need hardly any prep or shaping unless you was wanting a show car standard paint job then any brand of cobra would be up there in price .
im with wazza on this one what a strange question
cheers dean
xb-60 and Cobra01 like this.
a cobra is a passion anything else is just a car
i dont care what the question is .. The answer is more power!!!
  #499 (permalink)
Old 09-24-2014, 06:18 AM
damage's Avatar
Cobra Make, Engine: Kirkham 427SC 482 Cammer
Some one stole all the gauges and steering wheel ignition and warning lights.
  #500 (permalink)
Old 09-24-2014, 06:24 AM
guye's Avatar
Cobra Make, Engine: AP Pace427 (AP4033) GM L77 6.0L TR6060
Point is, the gelcoat is awesome. And I won't be painting it. At least not in its first incarnation. It isn't metallic or anything though of course, and a paint job would give you that. So, no, it probably isn't as good as a $10k paint job. It is different to a $10k paint job.
Dean is right though - I'd reckon the prep for a paint job would be easier with this finish meaning you could get a $10k paint job for maybe $7k
But what would I know - I'm only a computer nerd.
07cob likes this.
Guy
Cobra Progress guye-cobra.blogspot.com
