questions
- » Blogs
- » Image Gallery
million posts!
March 2025
1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
64Likes
06-29-2013, 09:25 PM
Well not many updates so far. The car is still sitting in the garage awaiting a heart transplant. No luck in sourcing an acceptable donor vehicle as yet, just waiting for the right one at the right price. Have bought a second 044 fuelk pump and currently making some brackets to mount the whole lot up. It runs 2 completely separate fuel systems. 2 x Holley Red lift pumps and 2 x Bosch 044 motorsport fuel pumps. One of each as a main and the other 2 as a reserve. The main 044 high pressure pump draws fuel halfway up the surge tank (it's about 40cm tall), the second (reserve) pump draws fuel from the bottom, effectively giving them about a 4 litre reserve.
Anyways I have found a video of the car from the last team it was raced with. Mine is the all blue #40 car.
Bluestone Fujitsu V8 Supercar Team Video - YouTube
Cant wait to get it all up and running!!
Advertising
06-30-2013, 04:21 AM
61.2 Ash!!!
07-06-2013, 06:06 AM
So........................
Now the fun begins, I have bought a donor car.
Got it from the damaged vehicle Auctions in Newcastle.
It's a 2011 VE series 2 SS ute (in blue of course!)
Bit of a mystery.... It has a 'next service due 15,000klm' sticker on the windscreen.
Stolen and Recovered...... Statutory Write off.....
Only things wrong with the vehicle.... 4 missing wheels, missing stereo, smashed passengers window, wires to fuse box cut.... That's it! I can't believe they Called it an 'unable to be registered again' Statutory write off.....
6 speed manual TR6060, good for 700ft/lbs apparently...Motor is an L77, unfortunately with AFM, which will need to be deleted...
07-06-2013, 06:22 AM
Q
Deleting the AFM is a perfect excuse for fitting a nice cam and valve spring package. I still can't believe how much power these make with just a cam, springs and a tune.
Did you buy the ute online, or were you down there for the auction?
Craig
07-06-2013, 06:42 AM
Some places are offering drive in drive out kits with the following
CNC Higgins heads
cam etc fitted
fully tuned
Some are claiming as much as 500 rwhp.... most between 450-500
$5700.....
Bloody cheap!!!!
Needless to say it should have at least 450rwhp..... with a dry sump
Mate I bought it online .... nervous times.... particularly because it was a Stat and there didn't seem much wrong with it...
07-06-2013, 12:41 PM
QLD
It perplexes me sometimes the reasoning that insurance companies have when it comes to write offs. Anyway, your gain.
You really have got it for blue cars, thats for sure.
Solid motor and cheap to get some good power out of, nice work.
07-06-2013, 03:27 PM
vic
Cobra Make, Engine: Python ford 302 ho, 4 speed toploader, jag irs 3.54
if the fuse box wires are cut, can you start it? i cant imagine how they stole it and got the engine going, must be some smart cookies that are thieves.
I remeber removing the radio from my ss and replacing with an SSV radio, then the car wouldnt start, and needed to be reprogramed to make it start.
07-07-2013, 05:00 AM
Qld
prob not to hard to get car started and running
remove and fit my reflashed ecu
get a wire and power up ecu another to power injectors and coils
and one wire to get starter to crank engine all done from under the engine bay
and wolla it might start but as ive never tried it im not 100% sure
and ive never tried to thieve a car because if anyone tried to thieve one of my cars even though they are std toyotas I would gladly pull the trigger while aiming at their faces heheheheh
07-07-2013, 05:04 AM
Qld
pity u cant repair it and sell it for a lot more
would prob take an hour to repair that cut plug as I have afew of them
then fit another radio and repair broken bits
07-10-2013, 01:01 AM
Vic
L76
Ash,
The DODS (Displacement On Demand System) can be drilled and filled, BUT
you must change the lifters........................................... .................................
My Daytona runs the L76, small heads and cam (not Higgins) tune and has
300rwkw. The L76 heads are suppose to be the best, they are the rectangular
type (Higgins uses them).
Great Motor
STIFFY
07-10-2013, 01:23 AM
Qld
u also might have to disable the DOD in the tune on late model engines
07-10-2013, 04:16 AM
Jim,
Yep I gotta get a DOD delete kit for around $600 which deletes all the unwanted lifters etc. bit of a pain.... Have ordered the dry sump stuff from the states. Wet sump wasn't gunna fit...
07-15-2013, 03:41 PM
Fingers crossed........... I think I have succesfully resized some photos small enough so they can be put on here... First pic is of the very nice stepped pipes that came with the car. Start at 1 3/4, then step to 1 7/8 then to 2 inch then into the collectors.... Then into 2 x 90mm pipes.... might be a little loud!
07-15-2013, 03:49 PM
Qld
Cobra Make, Engine: DRB, FORD 302W,T5
Not for LS heads ??
07-15-2013, 03:51 PM
You beauty! Success!!!!! It worked!!!!
Now a bit later I will do some more... gotta get back to work.
07-15-2013, 03:54 PM
Originally Posted by Mrs flatchat
Not for LS heads ??
No Chris, will have to get them modified......
07-15-2013, 03:59 PM
Ok now, work can wait......
A photo from the front of the car
Now from the rear
Showing the boot with dry sump system, resevoirs for brake and clutch, surge tank and the fuel system that was there.... some missing bits.
Just a picture of the dash. The motes is gone, have got a Racepak dash that will plug into the OBD2 port from the donor car...
07-15-2013, 08:48 PM
NT
Proper flash now.
Cruising in 5th
07-15-2013, 11:26 PM
QLD
Cobra Make, Engine: Absolute Pace 427 SC
Hi Towmaster
Nice Photos you must keep us informed with regular updates (Photos and a story or 2 )
There is nothing better than a cold beer
07-16-2013, 03:37 AM
Originally Posted by Cobra01
Hi Towmaster
Thanks Brad, good chatting to you at breakfast on Sunday, been watching your build also, good work.
Ash
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
