January 2025
26 27 28 29 30 31
Like Tree18Likes
Old 07-17-2013, 02:59 AM
Gav's Avatar
Gav Gav is offline
Default Taxi motor #2
Hi all, I thought I might get my backside into gear and post a couple of pics of the new taxi motor.
It is a 415ci cast iron gen4 with my old cam and heads.
The intake is new and the spacing of the throttle bodies was even the same as a Ford big block hence the air cleaner
[/IMG]
[IMG]http://[/IMG]
Cobra01 likes this.
Powered by Cu
Old 07-17-2013, 03:01 AM
Gav's Avatar
Gav Gav is offline
[IMG][/IMG]
Fair dinkum, posting pictures is a PIA
Rossba, Modena and Cobra01 like this.
Powered by Cu
Old 07-17-2013, 04:04 AM
dhs.buckley's Avatar
Cobra Make, Engine: Python ford 302 ho, 4 speed toploader, jag irs 3.54
Is it a case of badge engineering? Or when I grow up I want to be a ford
Looks great bet there will be a few ponies to hold back there!
Old 07-17-2013, 04:09 AM
Looks the goods Gav. Nothing 'taxi' about it from where I'm sitting.
Hope to put a few pics up of my build soon, chances are we will both have had transplants come Shelbyfest next year. I wont be packing the cubic capacity of your good self, but hope to be a little closer than before.......
Keep the info coming, all the best.
Chris & Melissa
Old 07-17-2013, 04:16 AM
Gav's Avatar
Gav Gav is offline
Not too sure what you mean there, looks VERY Chev to me.
I'm none too concerned with brands, it just needs to pack some muscle
Powered by Cu
Old 07-17-2013, 04:20 AM
Gav's Avatar
Gav Gav is offline
Chris & Melissa
Thanks guys, I will share a shed with you any day.
I have found out the hard way unfortunately that the Gen4 block differs from a Gen3 in one way so far, unfortunately it is a bolt hole in the block that the accessories all bolt to
Not a game breaker but a fair pain in the arse all the same!
Powered by Cu
Old 07-17-2013, 04:36 AM
Dimis's Avatar
Well done sir.
Looks like it will be one of the few "hold-on" engines that will suit a cobra.
I hope she servers you well for many the kilometres ahead.
Best wishes
Gav likes this.
Old 07-17-2013, 04:44 AM
sambo's Avatar
Great work Gav. That's the kind of look I'm aiming for - old schoolish with tech underneath. Are they efi carbies and if so, did they need a new ECU?
"A spectacularly fast car in a grand if dated tradition."
Old 07-17-2013, 05:03 AM
Gav's Avatar
Gav Gav is offline
Thanks Sambo,
They are EFI throttle bodies, they even have all the same plugs as the factory stuff (throttle position and idle air control) so the standard LS1 PCM will still be used.
The only down side is that Holley only makes the dual 4bbl manifold to suit the cathedral port heads at the minute. Hence why I have still got the LS1 heads on.
They will flow enough for now, and the low end torque should be killer!
Powered by Cu
Old 07-17-2013, 05:10 AM
Default Gav
Gav,
Looks great.
So is it now an opened GenIV
STIFFY
Old 07-17-2013, 05:16 AM
Gav's Avatar
Gav Gav is offline
Originally Posted by stiffy View Post
Gav,
Looks great.
STIFFY
Yep
It is a completely stock Schwanke Race Engines 415ci stroker.
Powered by Cu
Old 07-17-2013, 05:21 AM
Neutral
Gav,
Just as I expected, stock standard..........
Around 500 HP easy...........
Stiffy
Old 07-17-2013, 06:35 AM
tomcat racing's Avatar
Cobra Make, Engine: Some kind of FORD thingy, with several pis tins, twin chain driven SUs feeding a Y block, apparently.
Originally Posted by Gav View Post
Yep
Gav, keep that up,
and people will be calling you a stroker.
Nuts,,, Bolts,,, and 2 smoking barrels.
Old 07-17-2013, 06:37 AM
Gav's Avatar
Gav Gav is offline
I was waiting for it Tommy
The Schwanke brand name doesn't take much imagination to take the piss either
Powered by Cu
Old 07-17-2013, 06:40 AM
Brief change of subject,
Queensland, 8 straight how good is that,
As for the blues, go cry in yer beer for another year,
They will never beat that record.
Old 07-17-2013, 04:08 PM
David Hodgson's Avatar
Records are made to be broken Tommy
SLIPRY
Old 07-17-2013, 10:02 PM
Towmaster's Avatar
Hey Gav just wondering what sort Taxis had LS1 engines in them?
Old 07-17-2013, 10:27 PM
Aussie Mike's Avatar
Down in Melbourne you quite often see the Holdine Statesman used as a Taxi. I've been in a couple with the V8.
Mike Murphy
Melbourne Australia
Old 07-17-2013, 11:06 PM
Gav's Avatar
Gav Gav is offline
Victoria have all sorts of cool taxis, but mostly ones where the driver doesn't speak English, doesn't believe in deodorant and doesn't know direction in Melbourne.
Towmaster and d488y2 like this.
Powered by Cu
Old 07-17-2013, 11:22 PM
boxhead's Avatar
In Alice Springs there are 2 forms of hire transport, there is the Taxi company and for a few dollars more there is "Private Hire" these are almost all V8 Statesman vehicles, although there is now a Benz (X Taxi driver won a few million $ in Lotto earlier this year, so he bought a Benz to do Private Hire work for his regular customers)
Cruising in 5th
