questions
- » Blogs
- » Image Gallery
million posts!
November 2024
1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
19Likes
09-05-2013, 06:02 AM
AUS
Mando, this thread is a lesson on how to make a fantastic Cobra even better.
Amazing stuff, truly inspirational.
Advertising
09-05-2013, 06:04 AM
Originally Posted by OZCOBRA
I will then make this pledge to you Mando that I along with many others shall remind you othat ONE odd ball out of place fitting that SPOILS the whole finish and theme of your life's work!!! ...... DAILY!!!
Prick!
Regards.
Mando
09-05-2013, 03:23 PM
Q
Haha.
I wonder how many people over the years have been blinded by the incredible bling of your EFI system and failed to look at the level of detail that goes much deeper than just the intake. Your photos make it clear that this really is an obsession!
Craig
09-05-2013, 05:14 PM
QLD
Originally Posted by Mando
but to add to the nightmare they must be the same thread, the same length and the same manufacturer.Regards.
Mando, would I also be right to presume that you ensure that the allan heads all line up as well, meaning that a flat side either faces square with a side or rear.
I mention this as this is what I do.... all bolt heads must line up, all screw heads must line up.
09-05-2013, 05:25 PM
Leroy17, you sound as ridiculous as I do. After reading your post I also remembered that the stainless washers always have a slight rolled edge from being punched and that rolled edge must go against the nut or under the head of the bolt. CRAZY.
Regards.
Mando
09-05-2013, 05:34 PM
QLD
Regards.
Not crazy.... I do the same. However I have to say that I am nowhere near your standard. If Street Machine Magazine held a scrappynats.... then yeah.. I could enter.
09-05-2013, 07:30 PM
NT
You blokes are crazy.
As long as it works, I just drive the $hit out of it.
Cruising in 5th
09-06-2013, 02:13 AM
It's easy for you to say because your not the idiot.
Mmmm, that didn't come out the way I thought it would!
Regards.
Mando
09-06-2013, 03:19 AM
NSW
Mando,
I had one fitting I could not source in silver or polished. I ended up painting it!
Ben
09-06-2013, 03:38 AM
Vic
Regards.
I thought everyone did this
Ben in AU
09-06-2013, 05:57 AM
ACT
Yep, there's only one way to fit a flat washer.
Affliction or not Mando, that is a superb resultl. I just wish I had the patience to achieve it.
SLIPRY
09-08-2013, 06:08 PM
Qld
Perfection
Nice work Mando,
I see what you are doing as perfectly normal
My current project, I have new bolts all from the same manufacturer, size, thread etc etc.
However this is only for mock up as I have found a bolt source that has absolutely messed with my head.
Titanium, Stainless Steel, Aluminium Fasteners & Motorcycle Bolts | ProBolt
These will be used on my Panel Van Trevor and All of Grovers bolts will be ARP 12 point in black.
Love the arp stuff as there washers are a perfect fit.
Need therapy desperately, maybe I pick you up on the way.
Still my favourite car, when people see this they will be blown away, the detail is fanatical, and I have last seen it before it was finished.
Game changing car.
Phil
09-09-2013, 02:59 AM
Vic
Cobra Make, Engine: Classic Revival CR3514, LS3, Dual Quads, Holley Dominator EFI, TR6060, VE 3.7 LSD, AP Racing Brakes, 17x8 & 10 Custom Dragway Billet Wheels.
Drop by my place on the way to Mando's, might as well make this a group therapy session.
All my bolts are Durlok Flanged bolts, then black ceramic coated..... i know, i know.
http://cobra-cr3514.blogspot.com/
09-09-2013, 03:17 AM
Vic
And judging by the photos I could eat off the garage floor
I'm glad you guys post pics of your stuff. It's very impressive.
Gives me something to shoot for... Err dream about, is probably more accurate.
09-09-2013, 03:50 AM
DaveW, I've never head of Durlock bolts. Do they have a website?
Regards.
Mando
09-09-2013, 05:14 AM
Vic
Mando,
The're just a good looking flanged bolt, very factory looking, i like the look better than using a washer.
Lots of sizes so you can get just the ideal length.
I use the flanged nuts as well, they have a slight serration in the base that locks them up against vibrating loose.
i get them from here by mail;
https://www.bolt.com.au/bolts-durlok...1011_1042.html
Dave
