questions
- » Blogs
- » Image Gallery
million posts!
April 2025
1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
493Likes
12-30-2015, 03:45 PM
NT
Originally Posted by guye
Out of curiosity.
And this is probably more a question to Craig and or Wazza.
But the exposed suspension, does that create an ADR or compliance issue?
With the risk of binding if something is stored in the boot area?
Don't get me wrong, I love to see it, but just wonder of the legalities or practicalities?
Cruising in 5th
Advertising
12-30-2015, 04:37 PM
SA
Originally Posted by boxhead
Out of curiosity.
With the risk of binding if something is stored in the boot area? ....
There is some sort of plastic cover that isolates the suspension from the boot area. It keeps the dust out too.
Glen
12-30-2015, 05:07 PM
QLD
Glen,
You're right... there is a seal to stop dust/water from entering the boot area...
But I think the following will answer Box's question.
I think this is a pretty cool feature as well.
The finished boot area will have a panel that sits flat against the floor, but when you have a boot full of gear...this panel covers the suspension.
It swings up and is held in place with magnets.
Here's a quote from the Owner's manual:
The centre piece is designed to pivot at the front edge upwards and magnetically fasten to the zinc plated steel brackets fastened to the boot hinge mounting for the curved round tube.
The magnets are fastened into the centre panel.
and a couple of pics to show what we mean.
Cheers ( Happy New Year )
Wazza
12-30-2015, 05:15 PM
QLD
Also...
I thought the picture might bring up another question,
so just to finish off ...
Those two panels on the floor ( closest to the camera) at the very rear of the boot area, are removeable and open to reveal a large full width under floor storage compartment.
This is created by having the fuel tank sit as far forward as possible, and away from any potential impact area.
Again...Pretty cool I recon.
Wazza
12-30-2015, 07:30 PM
NT
Cheers Wazza, very clever.
Cruising in 5th
12-31-2015, 12:42 AM
wa
Guye here's a tip for you. Go to Bunnings and get some of the foil type tape they have. Looks the same as your insulation. I use a similar insulation on my 40 and use the foil tape to seal the edges off. Stops them fraying and finishes up the edge nicely. The tape is about 65mm wide so folds over both sides.
12-31-2015, 02:44 AM
Vic
Cobra Make, Engine: Pace 427SC. LSA Supercharged with 6sp TR-6060 trans.
http://www.carbuilders.com.au/aluminium-foil-tape
This is what I used on the interior to seal the Dynamat-type insulation up. Is that what you were thinking of?
www.paintwerks.com.au
12-31-2015, 03:19 AM
wa
This whati use. You can buy it from Bunnings. Put it on the edge and fold it over on all of your insulation jobs, looks trick.
Precision Paper Products - Australian Adhesive Tape Manufacturer
12-31-2015, 03:55 PM
VIC
Cobra Make, Engine: AP Pace427 (AP4033) GM L77 6.0L TR6060
Originally Posted by leroy17
Anyway, while you are at it, the hose clamp head slots are not aligned.
Arrgghh! Another sleepless night Leroy! I've also noticed the clamps are different brands so I went and bought a new complete set that match. Plus the hoses have differing textures. And the sealant isn't black to match. I'm going to on this till next year now!
Guy
Cobra Progress guye-cobra.blogspot.com
12-31-2015, 04:04 PM
VIC
Thanks Dave, I stuffed up the bonnet insulation a little bit yesterday (bl00dy contact adhesive is a b1tch!). I was thinking how I was going to tidy that up, so your suggestion solves two probs for me - edges and stuff up cover! Thanks!
Guy
12-31-2015, 04:07 PM
VIC
Out of curiosity.
What Wazza said, Dave. Thanks Wazza.
Plus I also added those luggage anchors and bought a nice set of colour matching straps that I'll use the restrict movement in the boot. I hate things rolling around in my car anyway...
Guy
12-31-2015, 04:17 PM
SA
Cobra Make, Engine: CR Cobra 3169
I'm not sure I would use steel zip ties around a hose. Over time with vibration etc, it will wear through. I have seen a breather hose lying on top of a ali rocker cover wear through the cover. A bit of oil on the hose with dust turns it into grinding paste. An easy way to isolate 2 hoses is use a small vacuum hose, run the zip tie through the vacuum hose around the hose your supporting back through the vacuum hose and around the other hose that your supporting.
JD
12-31-2015, 04:36 PM
VIC
Nice Jaydee. That worried me a little. The ties are only loose so I don't expect any abrasion.
However now I need to find some exact matching texture black vacuum hose to complete the work! Sigh.
Guy
12-31-2015, 09:33 PM
Qld
Uh oh....that has a Aussie Mike sound to it
Ferrari is red, Pagani is carbon, Shelby is blue,
because of these men...our dreams can come true.
01-23-2016, 05:32 AM
VIC
Another update and more pics.
This was just a bit of an at shot really. I was showing the scoop and bolt pattern, and only noticed the wheel reflection later!
Installed the dash, windscreen, squirters, demisters. Interior is looking pretty smart I reckon.
These are the specially modified euro cats to fit my setup.
The exhaust installed. 2-1/2" 304 stainless. I've used permatex copper for gaskets for now. I'm getting stainless gaskets made to match the custom flanges, but that might be a few weeks off.
The Pace427 accommodates undercar exhaust via a channel under the door sills. This is looking forward from the passenger rear. I've got this exhaust sitting low in the space, because at 2.5" it would fill the space a bit tightly and the level it is now is still about 10mm above the underside anyway. I think this will help reduce the heat into the cabin. Plus the cavity is lined with aluminised fibre cloth. And there is another air pocket. Then the cabin is lined with Dynamat. And carpet. Show be ok!
The mufflers fill the rear space. Now you see why I went overboard with the heat shielding. Can't hurt.
Rear wheel arches filled with another strip of aluminium to the body.
And finally lined with closed cell foam mat to reduce road noise and stone dents inside.
Guy
01-23-2016, 05:46 AM
SA
Nice one with the wheel reflection Guy!
The exhaust is looking good too. They (AP) thought of everything at the design stage with the chassis, and allowing for an integrated under-car exhaust is just another example.
Glen
01-23-2016, 02:49 PM
VIC
looking great Guy. That wheel reflection photo should be viewed with the music from the X-Files :-)
That is a very nice exhaust - will be great to hear it. (soon) :-)
cheers
Gregg
01-23-2016, 03:43 PM
Vic
Cobra Make, Engine: Classic Revival CR3514, LS3, Dual Quads, Holley Dominator EFI, TR6060, VE 3.7 LSD, AP Racing Brakes, 17x8 & 10 Custom Dragway Billet Wheels.
So impressive Guye, the work on the exhaust is first class too.
Dave
http://cobra-cr3514.blogspot.com/
Q
I haven't seen that additional wheel well strip of aluminium before. What does it do?
Craig
01-23-2016, 05:58 PM
sa
Cobra Make, Engine: absolute pace chassis #50 L98 & 6 speed auto
just a bit of a stone guard to stop stones geting flicked past the alloy underside and into the body work . im sure ive seen a few bits that shape in my pile of stuff that come with the kit .
a cobra is a passion anything else is just a car
i dont care what the question is .. The answer is more power!!!
