questions
- » Blogs
- » Image Gallery
million posts!
February 2025
1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
45Likes
05-31-2015, 02:59 AM
Q
...says the man with a naked #69 on the way..!
Cut, grind, cut again. If it doesn't fit, just keep cutting. Here is the state of car exactly one week after it was driven into the shed with the supercharged motor...
Engine sitting in its final location. Check out the size of those cylinder heads!
Back of the rocker cover sits about 10" behind where the firewall used to sit
20x15" wheels with 455/25/20 tyres are going onto the Chevelle. The 24x14" wheels with 405/20/24 Pirelli tyres were just lying around...
Craig
Advertising
05-31-2015, 03:21 AM
wa
Love it when shed Engineering kicks in...it doesnt fit so lets commit to making it fit. Cutting, grinding ,welding then a Swan appears like it was always meant to be....Keep up the good work.
05-31-2015, 03:51 AM
NSW
Wow - at any point has he regretted not putting this into something bigger...Like a Sherman tank, D9, or aircraft carrier?
05-31-2015, 04:43 AM
QLD
Hope the owner knows how to "pedal".
That is going be insane to drive.
Will barely need to steer with the front wheels,  .
Gary
05-31-2015, 04:44 AM
QLD
I have always been a fan of big engine swaps.
Winsor's into ford escorts, corollas, rx7's, LS conversions into Lexus is200, 911's, VW beetles, but this has taken things to a new level. This is just mentally cool.
08-07-2015, 04:49 PM
NSW
Anymore on this weapon Craig????
289 FIA Cobras RULE!
08-07-2015, 10:44 PM
Q
Dry sump pan had to be modified to drop the engine down low in the engine bay and to clear the control arm.
Sprint car air filter with a carbon fibre lid and CNC billet brackets. It originally sat flush with the throttle bodies, but here it has been dropped down to surround them fully.
When you see the physical size of this motor, it's astounding that it has been able to sit down so low and so far back into the engine bay. Unfortunately, despite this the owner is still not wanting to try to squeeze this under a 5" cowl scoop. The mega-dollar custom top mount throttle bodies are being removed at the moment and will be replaced by 2 x 125mm throttle bodies mounted onto the front of the tunnel ram plenum.
Steering part of the right hand drive conversion is done.
The Chevelle is having the exhaust done at the moment.
Racing seats being replaced with leather HSV seats.
Wiring is next.
Craig
08-08-2015, 12:35 AM
wa
sweet as Bru.....
08-08-2015, 05:19 AM
QLD
Looking at that engine a number of times.... That is just insanely big.
Incredible work and vision to make it work. Don't hesitate for updates as you get them.
08-08-2015, 05:21 AM
QLD
Double post.... But bugger it... Deserved for an insane motor
08-08-2015, 05:56 PM
Q
To try to grasp the physical size of it, here's what a coffee cup looks like compared to the intake runners on these motors...
Craig
12-04-2015, 04:19 AM
Q
Been a while since this was updated. With the goal to fit the motor under a factory steel bonnet, engine height was still a worry with the throttle bodies above the tunnel ram manifold, so there are now a couple of Plazmaman throttle bodies that have been mounted on a plenum "extension" on a common shaft.
Oh, and I just bought the Chevelle back, so now I am the proud owner of an unfinished project and a more powerful naturally aspirated motor than I ever thought in my wildest dreams that I would own. I am going to let the dust settle to decide what path to go down, but if you are genuinely interested in the possibility of buying this motor for your next insane project, let me know. I can see this engine in a GT40!
PS Leroy - this will NOT fit in the Arntz engine bay...
Craig
12-04-2015, 04:44 AM
CA
That is a monster of an engine and you have did excellent work on everything. I would really like to see a video of it running when you get it to that point. Congratulations on a great job.
12-04-2015, 05:08 AM
wa
GT40 now you are talking.....what's the plan Craig? Awesome project.
12-04-2015, 06:39 AM
QLD
Will be following this with interest.
Well done on achieving something that was not on the radar, sleepless nights ahead just sitting and looking at that in the shed.
Fitting into the Arntz, well nothing is impossible...... But maybe this is.
