December 2025
Like Tree327Likes
  #101 (permalink)
Old 06-07-2015, 09:10 PM
Gav's Avatar
Gav Gav is offline
Nice work, those pipes will be nearly identical as mine.
But hopefully less the annoying rattle that my driver side has.
They are loud but not too loud at cruise. WOT is a different matter all together though
Powered by Cu
  #102 (permalink)
Old 06-08-2015, 12:49 AM
David Hodgson's Avatar
Originally Posted by Modena View Post
4" tube. inner 2.5" perforated and it will be stuffed with steel wool stuff.
Looking good Ben. Just be aware that fine steel wool can burn.
SLIPRY
  #103 (permalink)
Old 06-08-2015, 01:33 AM
Cobra Make, Engine: Robnell Blown LS1
Steel wool burns easily.. Try lighting an old steelo pad !!
Possibly worth trying muffler packing which you can get from a local motorcycle shop.
  #104 (permalink)
Old 06-08-2015, 01:54 AM
Modena's Avatar
Thanks guys when I say steel wool I dont mean from uner the sink! I mean stainless steel wool muffler packing!
kyleb likes this.
Ben in AU
  #105 (permalink)
Old 06-08-2015, 01:56 AM
Modena's Avatar
I know about domestic steel wool, we used to use it as fire lighters in Scouts
Ben in AU
  #106 (permalink)
Old 06-08-2015, 02:50 AM
Gav's Avatar
Gav Gav is offline
Once you have the wool on buy a cheap working blanket and wrap it with that before sliding it into the outer pipe.
It drops the outer temp of your side pipe by a mile.
Powered by Cu
  #107 (permalink)
Old 06-08-2015, 03:52 AM
Default Pipes
Great work Ben,
Im so happy that your floor looks as dirty as mine
STIFFY
  #108 (permalink)
Old 06-08-2015, 03:57 AM
Gav's Avatar
Gav Gav is offline
Once you have the wool on, buy a cheap welding blanket and wrap it with that before sliding it into the outer pipe.
Powered by Cu
  #109 (permalink)
Old 06-08-2015, 11:08 PM
DaveW's Avatar
Cobra Make, Engine: Classic Revival CR3514, LS3, Dual Quads, Holley Dominator EFI, TR6060, VE 3.7 LSD, AP Racing Brakes, 17x8 & 10 Custom Dragway Billet Wheels.
Good for clean emissions though
Aussie Mike likes this.
http://cobra-cr3514.blogspot.com/
  #110 (permalink)
Old 06-08-2015, 11:41 PM
Aussie Mike's Avatar
Throw in a couple of dishwasher pellets while you are at it.
Looking good Ben. Good to see people with a have a go attitude.
What the reason for welding all of the primaries together along their edges?
I remember Craig (750HP) did something similar but cut the internal sections of the pipe out to make it one big pipe out of 4 smaller pipes. I think for the reason that he needed shorter primaries and a longer collector for his blown motor.
Have you got tyres and wheels fitted yet?
Mike Murphy
Melbourne Australia
  #111 (permalink)
Old 06-09-2015, 05:23 AM
Modena's Avatar
Mike you're asking me questions like there might be some kind of science behind the answer.....umm......nup.
Ben in AU
  #112 (permalink)
Old 07-19-2015, 06:03 PM
Modena's Avatar
A few more small jobs ticked off.
Finished the charcoal canister plumbing, plumbed up the fuel filler neck, made a bracket and mounted the coolant overflow bottle. Also rewired the EGR purge valve as I moved the valve to a different spot than I had originally planned, and wired the water temp gauge sender
Ben in AU
  #113 (permalink)
Old 07-20-2015, 01:22 PM
leroy17's Avatar
Another step forward, looks good. Those black fitting sure look nice on everything and aeroflow make quality function parts.
Keep going with the updates.
  #114 (permalink)
Old 08-16-2015, 05:51 AM
Modena's Avatar
Another weekend closer to the Nationals, e-gad!
Complete exhaust system is now finished up and ready to go for ceramic coating;
Pulled the windscreen off to drill the holes for the centre bracket, mounted the rear view mirror and also the visors and windwings
Also finished up the fuel system, tightened alll the fittings, fitted the washer jet plumbing. Still plenty more to do before October....
boxhead likes this.
Ben in AU
  #115 (permalink)
Old 08-16-2015, 05:54 AM
Modena's Avatar
Aussie Mike, guye, boxhead and 2 others like this.
Ben in AU
  #116 (permalink)
Old 08-16-2015, 06:33 AM
stephen low's Avatar
Ben
Don't those exhaust tips on the side pipes need to have some amount of downward deflection to meet ADR's?
I didn't think they could point sideways as they seem to appear in your photos?
Good work regardless by the way!
boxhead likes this.
slowy
  #117 (permalink)
Old 08-16-2015, 06:38 AM
Modena's Avatar
No I don't believe so. Pipes are not allowed to face upwards - typically this is referring to rear exit, but the ADR no longer state anything about side exit, so same rules apply, it needs to be horizontal or downwards.
Ben in AU
  #118 (permalink)
Old 08-16-2015, 06:35 PM
leroy17's Avatar
Building your own pipes, this has been really cool to follow, right from the start with the early mock up from the heads, to having the headers made to this.
Looks really good and in poportion, like the Aussie mike ones as well. Will be good to see coated as well.
  #119 (permalink)
Old 08-16-2015, 08:55 PM
Cobra Make, Engine: absolute pace chassis #50 L98 & 6 speed auto
certainly looks the goods .
i will have a go at building most things in metal from chassis too trailers but somehow the thought of doing the pipes scares me a little so hence i prob will just pay to get mine done but kudo's to the guys that build your own well done .
cheers dean
a cobra is a passion anything else is just a car
i dont care what the question is .. The answer is more power!!!
  #120 (permalink)
Old 08-17-2015, 06:47 PM
Default Exhaust
Benny,
Great work, you will certainly be attending the Nationals.......
Stiffy
