November 2024
Like Tree12Likes
  #21 (permalink)
Old 10-10-2014, 05:00 AM
leroy17's Avatar
I used on my Harrison a Goodyear GSD3 285 40 17. I can assure you that not all tyres are created equal. These measure out to nearly 300.
Plus, they were a little taller in the sidewall which really helped fill a guard. Running 245 45 17 in the front gave a little rake as well that looked in proportion.
The GSD3 was squeezed on a 10 but looks best with a 10.5 rim. This tyre had a AA A rating with tread wear of 180 for memory.
Do some google image searches to give an idea compared to others.
  #22 (permalink)
Old 10-10-2014, 05:01 AM
leroy17's Avatar
There is a good pic comparing a sumitomo 315 35 17 and a GSD3 315 35 17.
Wayyyy different, I will see if I can find it, it shows that the GSD3's measure big.
  #23 (permalink)
Old 10-12-2014, 03:45 AM
gjkrv8's Avatar
Originally Posted by Modena View Post
mmm this may make the case to run a 17" tyre. According to this in 17" there are 285 and 295 available, yet in 18 it goes from 275 to 315.
ECSTA XS - Kumho Tire USA, Inc.
Gregg is there any room to move the wheel outbound by 10mm, or would it start hitting the guard?
Ben
Hi Ben - yes on the passing side there is room under guard to move it out.
will chat to you about methods.
The taller 295s didn't rub either side by the way.
cheers
Gregg
