February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Like Tree7Likes
  #41 (permalink)
Old 11-04-2015, 08:22 PM
stephen low's Avatar
Sounds like the right sort of plan, then you can be sure and tick those details off as issues if the problem wants to persist.
slowy
  #42 (permalink)
Old 11-16-2015, 04:42 AM
snakesaway's Avatar
Cobra Make, Engine: Evans and Wooley, 302 Windsor, Supra turbo 5sp
Curiosity and my uncle finally convinced me too grow a set and pull the heads off to check the head gasket to see if it was backwards (as Rob had suggested the man is never wrong). So as the head came off and I saw the gasket on backwards a huge sigh of relief followed by a loud cheer. Anyway the heads are away being crack tested and checked for warping hopefully all clear on both fronts. I am a bit nervous about getting the rocker right but really shouldn't be that hard as they are the non adjustable variety (gotta love hydraulic lifters) I just hope I have them back in time to have the car running for the club run Sunday.
cheers Andrew
  #43 (permalink)
Old 11-16-2015, 05:13 AM
Cobra Make, Engine: absolute pace chassis #50 L98 & 6 speed auto
ah good so now when it goes back together your heating probs should be fixed . with summer getting warmer prob not a bad idea to get it done now
a cobra is a passion anything else is just a car
i dont care what the question is .. The answer is more power!!!
  #44 (permalink)
Old 11-16-2015, 05:35 AM
LoBelly's Avatar
... and now your voice will drop and you'll be able to earn the cash for more upgrades by doing voice overs
double win
LoBelly
snakesaway likes this.
  #45 (permalink)
Old 11-16-2015, 01:49 PM
dhs.buckley's Avatar
Cobra Make, Engine: Python ford 302 ho, 4 speed toploader, jag irs 3.54
Originally Posted by snakesaway View Post
Curiosity and my uncle finally convinced me too grow a set and pull the heads off to check the head gasket to see if it was backwards as Rob had suggested the man is never wrong). I am sure you all could have heard the cheer on Saturday arvo. Anyway the head are away being crack tested and checked for warping hopefully all clear on both fronts. I am a bit nervous about getting the rocker right but really shouldn't be that hard as they are the non adjustable variety (gotta love hydraulic lifters) I just hope I have them back in time to have the car running for the club run Sunday.
cheers Andrew
So after all that was the Gasket on backwards?
  #46 (permalink)
Old 11-17-2015, 03:28 PM
snakesaway's Avatar
Opps just re read the post I forgot the vital piece of information yes the head gasket was backwards, the reason for the loud cheer. Must have been the apprentice engine builder or the friday arvo build after lunch at the pub.
dhs.buckley likes this.
  #47 (permalink)
Old 11-17-2015, 03:41 PM
*13*'s Avatar
I read through the first page & see you have a couple more pages of suggestions so i'll just be short & sweet.
Make sure you check your timing. bring the #1 piston to TDC & see that the timing mark aligns on your balancer.
Location of your thermostat can make a difference. I have a remote, inline stat that opens in cooler water than is in the block.
Lastly. If your engine is still fresh, it can run a little warmer before it breaks in. Drive accordingly until then.
ERA FIA 2088
  #48 (permalink)
Old 11-17-2015, 08:53 PM
Well at least the primary culprit has been identified and you didn't do all that work for nothing!!
Should be all plain sailing from here on now Andrew.
"The Flash" ( A stiffy-ism)
slowy
  #49 (permalink)
Old 11-17-2015, 09:20 PM
snakesaway's Avatar
Well i hope so. That was my biggest fear, was that I pulled the head off and found the gasket wasn't backwards.
  #50 (permalink)
Old 11-18-2015, 07:34 PM
Cobra Make, Engine: Researching the right car now.
Originally Posted by Towmaster View Post
Make sure there is no air gap between your fan shroud and the radiator. If there is a gap there then air will pass through it rather than be sucked through the radiator, therefore decreasing the effect of your thermo fan. You can buy adhesive rubber of varying thicknesses from Clark rubber. This is perfect for sticking in any gaps between your fan and the radiator. These little 5% differences really add up...... Having said that my LS sits around the 200 - 210 mark in racing situations.
Good suggestion. If there is a gap, when sitting in traffic, the fan will pull hot air from the engine bay, through the gap in front of the radiator, and then back through the radiator. Fresh/cool air vs 120+ air makes a big difference. I had an excavator that would over heat...turns out the shroud around the edge of the radiator was bent and allowed the hot air to cycle back through the radiator. Sometimes it is the simplest of things.
  #51 (permalink)
Old 11-19-2015, 05:59 AM
cycleguy55's Avatar
Yeah, that would suck. Good to hear you've found and fixed the problem.
Brian
  #52 (permalink)
Old 11-22-2015, 01:39 PM
snakesaway's Avatar
Well what a weekend spent all Saturday finishing off re assembling and after 2 goes at tweaking the values I still had a tapping sound. I gave up in disgust and went to the bar. Sunday arvo a mechanic friend offered to come over and have a look fired it up and there was the tapping sound, pull the passenger rocker cover and there was a very loose rocker arm must have had the cam in the right spot when i tighten it up bugger. Checked all the rest all ok, rocker covers back on AGAIN. Fired it up no tapping chattering. You rippa. Just a pity something so simple stopped me making the club run.
  #53 (permalink)
Old 11-23-2015, 06:00 PM
snakesaway's Avatar
Well after a few test runs and driving it too work in the traffic this morning the temp gauge barely moved off 180 F but it was cool morning. So now I just need to wait for a hot day and some traffic for a real test. But suffice to say with the fan coming on at the lights then turning off while moving. I guess the problem is FINALLY sorted if its not be buggered if I know what it is. thanks to everyone for there input and to Rob from the club for his invaluable advice and patience.
Andrew
  #54 (permalink)
Old 11-24-2015, 02:56 AM
Default Overheating
Andrew,
Great to hear the issue seems to be fixed, nothing worse than a car
that overheats.
This is why club membersship is so valuable, it has saved you time
and more importantly money.
STIFFY
