questions
- » Blogs
- » Image Gallery
million posts!
March 2025
1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
105Likes
11-30-2016, 03:19 PM
sa
Cobra Make, Engine: absolute pace chassis #50 L98 & 6 speed auto
very nice i like the step i need something like that on mine even with 4 inch drop axles it's a bit of a step ..kinda wish i went gooseneck now maybe next time lol
a cobra is a passion anything else is just a car
i dont care what the question is .. The answer is more power!!!
Advertising
12-02-2016, 05:34 AM
Bit more progress, nearly have the main area all painted now. Should have it all done by the weekend.
12-04-2016, 04:41 AM
More progress this weekend. Had other things on so not as much as I had hoped. Managed to get a good coat on the front section. I might put an ally checker plate section to save more stone chips.
12-04-2016, 06:19 AM
wa
Looks good Ash, I know you will do a mint job by your last trailer.
12-04-2016, 02:22 PM
vic
You need to be doing a bit less loving and a bit more working Ash!!!
Powered by Cu
12-05-2016, 06:36 AM
A bit more progress tonight. Two coats Of white exterior to seal the underside of the quilla flooring for the living area and I have started to cut out and fit the formply flooring. Not too many swear words so far...
12-05-2016, 03:59 PM
sa
looking good there mate . i went full alloy floor as i was trying to save weight as best i could , and just used marine carpet around the front nose cone part where we use the micro wave and kettle and sit around space .
what are you cladding the sides with ? i used that alcubond sheeting on mine
cheers dean
12-06-2016, 06:02 AM
A bit more progress, 5.4m of form ply in place. 3.2 m of hardwood flooring to go in the front half yet.... Still needs to be pulled out sealed and then sika flexed in place. Don't need it to move... form ply will be heavy but I'm allowed 4.5 tonne and it was only $65 a sheet and this is a budget build. I'm using 3mm aluminium composite material, get it from our acrylic suppliers for about $25 /sqm. Will use some polished extruded aluminium on the edges and have plenty of lights for it. This thing needs to be ready and registered by last weekend in January to take the car to Bathurst.... not toooooo concerned just yet..... I have pretty much everything I need except the extrusions. Will ring & check when they close for Xmas....
12-06-2016, 05:30 PM
sa
who do you get the polished extruded alloy from ? i was looking for some when i did my trailer in the end i just used 50 mm alloy angle as its all i could find at the time but i would like to replace it with something nicer ..
12-07-2016, 05:06 AM
Originally Posted by deano59
who do you get the polished extruded alloy from ? i was looking for some when i did my trailer interesting the end i just used 50 mm alloy angle as its all i could find at the time but i would like to replace it with something nicer ..
I'm getting mine from Action Aluminium in Brisbane. They have the truck body polished extrusions. I just googled polished aluminium extrusions and they came up. Ullrich Aluminium is another one but not sure exactly what they have.
12-07-2016, 06:21 AM
VIC
I use Action Aluminium here in Melbourne. Excellent range and have most things in stock.
Action Aluminium
Mike Murphy
Melbourne Australia
12-07-2016, 02:59 PM
sa
thanks for that we a Ullrich mob not far from me thats where i bought the angle stuff from i will ask again about the polished stuff when i go past next. cheers for the heads up
12-10-2016, 06:04 AM
Quilla flooring done. Will fill in the gaps with some marine ply as there will be cupboards, shower etc down that side....
12-10-2016, 06:15 PM
sa
whats the total length of the trailer from the nose at the fron the the rear non including the hitch ect just the trailer box itself if that makes sense .
12-10-2016, 08:53 PM
The flat floor is 8,550mm & the raised bed section is 1,850mm long.
Total external length is 11m with fibreglass nose cone.
12-10-2016, 09:35 PM
Did a bit of measuring & it turns out I could do it all in the hardwood. Have enough left over for a hardwood bench top also.
12-11-2016, 01:43 AM
More progress...
12-11-2016, 08:27 PM
That thing is massive LOL. I'll be popping around over the Christmas to have a looksy. Hope the ole 6cyl has had a tune up!!
12-11-2016, 08:42 PM
wa
Looks like fantastic progress Ash.....Can you make sure my GT40 fits? When you move up to a semi I should be ready to take this one off your hands....lol...
12-11-2016, 11:21 PM
NT
Thats a big arsed wind break.
Cruising in 5th
