January 2025
26 27 28 29 30 31
Like Tree105Likes
  #61 (permalink)
Old 12-12-2016, 03:55 AM
Towmaster's Avatar
Thats a big arsed wind break.
Yep I felt it all the way back from Darwin. It's a pity that old ohc 5.4 triton V8 doesn't have as much torque as my little 6 cylinder.... even that was enough for a 115kmh speeding ticket on the way back.
boxhead likes this.
  #62 (permalink)
Old 12-13-2016, 06:41 AM
Towmaster's Avatar
A bit more progress.... fitted the caravan door (with fly screen) & retractable step this arvo before cricket. Waiting on more glue for the sides..... have started on wiring, Andersen plug, break away etc and mounting the winch. Momentum momentum momentum.....
boxhead likes this.
  #63 (permalink)
Old 12-13-2016, 07:45 PM
When you do your wiring don't forget to wire in ya TV aerial.
Also, with your windows, if you can definitely put some in the sleeping area. Your head room looks tight and even with mine having that bit more headroom it can feel a little enclosed.
  #64 (permalink)
Old 12-14-2016, 07:28 AM
Towmaster's Avatar
Wheel arches cut in, 400mm high checker plate will run along the bottom of the body and flare out a little over the wheels. Ply template was cnc cut and refined to this shape. Pretty happy so far. Also got the aluminium extrusions you can see sitting on the top rail.
deano59, boxhead, spookypt and 2 others like this.
  #65 (permalink)
Old 12-15-2016, 07:13 AM
Towmaster's Avatar
Not much tonight, removed the 3 old broken adjustable roof vents and installed 3 new ones. Time consuming to remove all the silicone etc and make sure the new ones are sealed against the weather. Also cleaned one top side in prep for fitting the aluminium extrusions. Once again loads of silicone to remove.
Also bought an air operated rivet gun!!! OMG how freaking good are they!!!
Gav likes this.
  #66 (permalink)
Old 12-15-2016, 04:37 PM
Cobra Make, Engine: absolute pace chassis #50 L98 & 6 speed auto
whats the roof made of ? i like the air vents thats something i need to put on my trailer .
cheers dean
a cobra is a passion anything else is just a car
i dont care what the question is .. The answer is more power!!!
  #67 (permalink)
Old 12-16-2016, 01:49 AM
Towmaster's Avatar
cheers dean
The roof is one piece aluminium. It's a single sheet that is 10.5m long and 2.5m wide. I would hate to have to replace it.....
deano59 likes this.
  #68 (permalink)
Old 12-16-2016, 09:35 PM
cheers dean
Those Air Vents would be called a VENTLINE 14" Hatch and available from any caravan/ RV store. There is a version of it that has a 12v fan in it to suck the air out ( used in the shower cubicle of an RV). Another model is called a JENSEN Hatch. Hole in the roof needs to be 360mm x 360mm.
Andrew
  #69 (permalink)
Old 12-16-2016, 11:25 PM
Cobra Make, Engine: CR Cobra 3169
What is the best shape for the front to reduce drag? A v nose or a angled front?
JD
  #70 (permalink)
Old 12-17-2016, 12:42 AM
Andrew
thanks for that andrew at least i know what i am looking for now
cheers dean
  #71 (permalink)
Old 12-17-2016, 12:53 AM
JD
hi jaydee
when i did mine i made the roof area start at the same height as the canopy on my ranger and the sides start off the same width as the back of the ranger
it tows really well and to be honest even loaded the ranger pulls it quite easily. i have towed some trailers that are just flat across the front and it is like towing a block of flats. i like to think with mine the air passes over the canopy roof then shoots up and over the trailer roof and the same as the sides
  #72 (permalink)
Old 12-17-2016, 02:00 AM
I remember those deflectors people used to bolt to the roof racks. Semi's use them.
JD
  #73 (permalink)
Old 12-23-2016, 03:41 AM
Towmaster's Avatar
Bit more progress lately. Rear door cover on and all lights in and wired. Allot trim not yet. Have also installed the wheel arch covers. Still a bit of work to do. Will be working on getting the nose cone and wiring for nose cone high level indicators and clearance lights, have a bit of time off over Xmas / New Year so need to get stuck in to it.
schipps likes this.
  #74 (permalink)
Old 12-23-2016, 03:49 AM
Towmaster's Avatar
Wheel arch covers
  #75 (permalink)
Old 12-23-2016, 03:54 AM
Towmaster's Avatar
Wiring to rear of F truck
boxhead, Gav, Wazza and 1 others like this.
  #76 (permalink)
Old 12-28-2016, 07:42 AM
Towmaster's Avatar
Little more progress over Xmas break. Have got some more of the bright trim installed.
Electric brakes and break away is all wired in as is the real lights. More shiny trim to install & start on the 50+ clearance lights....
Wazza likes this.
  #77 (permalink)
Old 12-28-2016, 03:52 PM
looking nice there mate . thats the same breakaway unit i put on mine they work pretty good as well .only thing i did was not use the battery that come with it i wired it straight into the big battery in the trailer i used the box with the charge lights ect but just extended the wires from it to my main battery .
cheers dean
  #78 (permalink)
Old 12-28-2016, 08:30 PM
Wazza's Avatar
Looks awesome Ash....really well done.
Warren
  #79 (permalink)
Old 12-28-2016, 10:24 PM
boxhead's Avatar
Not as flash as yours Ash, but a mate who is collecting my trailer in Melbourne sent me a pic today.
He grabbed a couple of box trailers to bring out and sell as well.
[IMG][/IMG]
BJ's Snake and Towmaster like this.
Cruising in 5th
  #80 (permalink)
Old 12-29-2016, 02:36 AM
Towmaster's Avatar
cheers dean
Yep I had the same on my other trailer too, hooked the wires to the Andersen plug so it's charging all the time.
deano59 likes this.
