questions
- » Blogs
- » Image Gallery
million posts!
January 2025
1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
28Likes
09-06-2016, 02:36 AM
NSW
Originally Posted by Gav
Andrew's driving has been pretty jerky both in and out of the car so you may well be onto something Mike.
Brave move for you to comment on anyones driving given recent events Gav
Good info Mick - Mine makes peak torque at about 1200 rpm now so all good . Ill basically be idling around at nats.
Advertising
09-06-2016, 02:46 AM
vic
I was a passenger...
Powered by Cu
09-06-2016, 03:25 AM
Vic
oh so like last year then.
Ben in AU
09-06-2016, 04:57 AM
VIC
That was basically the problem Garret had. at 1200 RPM with the blower it's starting to make boost and a bunch of torque.
Mike Murphy
Melbourne Australia
09-06-2016, 05:07 AM
NSW
what where you doin then?
Andrew Cornett (NSW) 1:10.5430
Ben Holko (VIC) 1:11.0390
09-06-2016, 05:43 AM
Vic
Lulling you into a true sense of security (my car did have 30kms on it (it doesnt anymore)).
Ben in AU
09-08-2016, 05:24 AM
NSW
My psi conversion loom for manual trans includes brake sensor but not clutch (or maybe I just ran the clutch to earth). The brake switch for Ecu is normally open. I just checked the psi manual and it says it's used by the drive by wire system. It says failure to wire correctly could result in the accelerator not working.
Regarding the speedo, do you maybe need a pull up resistor on the circuit?
Reason: Changed brake info
09-08-2016, 06:57 AM
NSW
Interesting Liam. I've added in the brake inputs tonight as I figured it couldn't hurt. Curious to see if it makes a difference.
Some good news, fans are working perfectly after the latest tune. That big radiator of mine works well though. Hard time getting it up to temp so fan comes on (97)
09-15-2016, 04:14 PM
NSW
Fans and Tune are now sorted - The extra torque with that baby cam is scary. Whether it equates to better times remains to be seen. Tyres and brakes already close at limit so I suspect not.
Still need to get the ECU speedo signal working. That one has me stumped.
09-15-2016, 08:12 PM
Vic
what's the speedo problem? The ECU puts out 5v square wave, is your speedo working at all?
Ben in AU
09-15-2016, 09:09 PM
VIC
Ben I think Andy's problem is getting his ECU to recognise the speedo signal from the transmission sensor etc.
09-16-2016, 12:45 AM
NSW
Correct Greggy. No Speed in the ECU, but it is definitely getting the signal from the (stock) T56 vss as I piggy back off that to the speedo direct and it works no problem. There is no getting the reverse lockout working if I cant get a speed in the ecu - at the moment I have a little overide switch on the console. Not a biggy but one of the little niggles Id like to sort out eventually.
09-16-2016, 06:35 AM
VIC
Cobra Make, Engine: AP Pace427 (AP4033) GM L77 6.0L TR6060
Andy, I know your vss signal works for your speedo, but when you tried hooking it up to the ECU, did you disconnect the speedo?
And did you try swapping the pins as Ben and others suggested?
Failing that, another option is to use the brake light - wire that direct to the lockout solenoid (via a relay) bypassing the ECU altogether. So you can only select reverse while your foot is in the brake.
But getting speed to the ECU is better. If you want to use things like Harry's Laptimer or Dashcommand, or just service computer read, off the OBD2 port you'll be missing heaps of info. Not to mention the diagnostics will be reduced - distance since last reset, fuel consumption stats, etc (I know, I know, who cares about fuel consumption - but you get what I mean...).
Guy
Cobra Progress guye-cobra.blogspot.com
09-16-2016, 06:45 AM
VIC
(By the way, the reason I suggest disconnecting the speedo is maybe it's drawing to much current or something. I had problems getting both my speedo AND the ECU to work off the 'box sensor; in the end I connected my speedo to a different sensor; an unused wheel abs speed sensor).
Guy
09-16-2016, 06:52 AM
NSW
Yep tried swapping wires and unhooking speedo. Good info though Guy, the tuner has mentioned most commodores take the vss off the abs sensors now.
09-16-2016, 04:32 PM
VIC
Correct, Phil in VIC also had to do that with his CR as his donor VE Transmission didn't have a speed sensor on it. Maybe give that a go. Easy to test as you just take it off one of the front wheels and jack it up and spin by hand it to see if the ECU registers a signal or not.
09-17-2016, 08:22 AM
Guy, did your gearbox have a 2-wire (i.e. unpowered, inductive type) VSS? and likewise the wheel sensor?
Mike
09-17-2016, 05:27 PM
NSW
ECU speed working!
After having another whinge at the tuner he sent me screen shots for the vss parameters he could change. What was pretty obvious to me, and not to him, was the little box that said "Transmission output shaft sensor" had a No in it. He had it all setup for ABS speed sensors (via a non existent BCM I think). Despite me telling him 1000 times what my setup was.
Anyway - now on to seeing if I can get rid of the reverse lockout switch.
09-17-2016, 06:34 PM
Vic
Good that you found the "problem", why do you want to get rid of the reverse lockout?
Ben in AU
