April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Like Tree9Likes
Old 11-06-2017, 05:13 AM
DanEC's Avatar
Originally Posted by Ron61 View Post
To loosen mine I use a spinner removal tool that works great and saves beating on the ears with the lead hammer. It fits over one ear and hooks to the wheel and then you use a 3/4 wrench to tighten it. If it is to hard when you get it tight whack the spinner with a hammer to break it loose and them finish with the removal tool.
Can you post a picture of it Ron?
ERA 782 Running
Old 11-04-2017, 04:22 PM
Gav's Avatar
Gav Gav is offline
I bought my hammer from the Healy factory and my pliers and wire came from Revolution Racegear.
A bit of anti seize will stop things from binding or corroding together.
When you are tightening things up there will be a noticeable change in tone when the nut takes up and is tight, in other words it will sound different when you hit it and it's tight.
Powered by Cu
Old 11-04-2017, 04:41 PM
stephen low's Avatar
Thanks guys the sort of stuff I need to know.
What is the anti-sieze suggested then.
Seems I'm filling up my toolbox now with other "extras" - ha
slowy
Old 11-05-2017, 05:00 AM
this thread has inspired me to go googling spinner tools. here's one:
Sarto Rocheleau -  CobraHalibrand type Spinners      If your Halibrand spinner looks like this one, the tool will fit.This tool applies equal force to all 3 ears of the spinner without distorting the spinner.     The tool drops onto the s
Old 11-05-2017, 03:49 PM
Karl Bebout's Avatar
One other little trick I did is that I drilled 1/8" holes in all the spinner ears so that I have more choices of just where I attach the safety wire. This prevents having a wire running in the way of reaching the air valve stem.
rodneym likes this.
Karlos
Old 11-05-2017, 05:03 PM
HI Cobra's Avatar
Karl - that reminds me that this winter I will be drilling those extra holes in my spinners. I have one that ended up like that close to the air valve. I can still
check and put air in but it is a minor pia.
Flip
Old 11-06-2017, 05:12 AM
DanEC's Avatar
When tightening the spinner with a lead hammer, whack it lightly a few times to snug the wheel up, but then drop the car to the ground and load the wheel/tire with the car's weight before you tighten the spinner. Trying to beat on it with the wheel in the air is just beating your bushings and bearings.
xb-60 likes this.
ERA 782 Running
Old 11-11-2017, 04:33 PM
Guys
I was doing a bit of reading about the anti-seize products, as I wondered what reaction with the aluminium rims, knock-off shaft and spinners the various anti-seize products might have.
Realised I have a tub of Loctite Nickel 771 compound in my chemical stocks and this seems to read as ok to use. It is a high heat resistant variant but it is the chemical mix that is of concern to me.
Anybody got some definitive advice of the nickel based product and potential reactivity?
I know I'll never use up this tub of product so trying not to buy a second different tub.
slowy
Old 11-12-2017, 02:01 AM
Gav's Avatar
Gav Gav is offline
Nickel will be fine, that's what I'll use.
Btw it's a bastard to clean up, my wife once complained about some of it getting on our carpet (beats me how it got there) CRC contact cleaner gets it off beautifully.
Powered by Cu
Old 11-12-2017, 09:46 AM
In aerospace we use a lot of LB 771 (Nickel) anti seize on turbine engine parts.
Rule of thumb is to grab a pair of Black Nitrile gloves when using it. (good below 2400F)
(Nickel is a cancer causing agent) SDS (used to be called MSDS sheet)
http://hybris.cms.henkel.com/henkel/...N&matnr=235028
For normal use areas like landing gear, bleed air plumbing, flight controls (good below 1800F)
C5-A (copper) anti seize is typically used.
http://hybris.cms.henkel.com/henkel/...US&language=EN
Old 11-12-2017, 12:21 PM
Thanks guys for the confirmation. Had read it can be a pain if not used sparingly.
Good tip on the chemical hazard too ta.
slowy
Old 11-13-2017, 11:29 AM
super's Avatar
Cobra Make, Engine: Superformance, #011
Stephen,
as I already mentioned, I use a product from Weicon. I am not sure if you will get this over there, but I like it.
It is white, metal free, ceramic based.
This is the link to the technical data sheet:
Anti-Seize High-Tech | Coating and Protecting | Oil and Gas | Industries | WEICON Germany
And here a picture to how it looks like:
Old 11-13-2017, 02:02 PM
Super
I'm sure I could source the product if I had the will but just don't need another chemical in the midst of the myriad of others I have accumulated in the garage, especially with a suitable anti-seize to hand.
The nickel variant is carbon grey but I'll be sparing in its use.
Thanks anyway.
Steve
slowy
Old 11-18-2017, 04:38 AM
I use a product called GOOP . It is used in steam turbine applications .. A bit expensive as it's based on a silver compound. Very durable and doesn't walk or fling.
Rate This Thread:
