02-12-2004, 02:12 AM
NT
I can understand the excitment.
Have you checked if there will be any troubles like pneal had regarding year of the engine?
If the engine has a number stamped on the block head surface at r/h front corner then it should start with a VF then 2 numbers, these 2 numbers are the year the engine was built
ie; mine says VF00******* so it is a 2000 model
Cruising in 5th
