November 2024
Old 05-07-2005, 08:57 PM
Cobra Make, Engine: Classic Revival. LS1, T56, Billy Cart
Default CR arrives next Saturday
Got an email from Ian, saying that the chassis will be ready to pick up at the end of this week. Yipee, now the fun really begins.
Also had a look at an LS2 at Eagle auto last week. Being that the throttle body is fly by wire, does anybody know if you can adapt an LS1 mechansism to it ?
Old 05-07-2005, 10:59 PM
boxhead's Avatar
Hey there churchy, I have an LS1 throttle body your welcome to if you want it.
Cruising in 5th
Old 05-08-2005, 12:14 AM
Aussie Mike's Avatar
Congratulations Churchy!!
LS2 has a 90mm throttle body where the LS1 only has a 75mm one. Unfortunately they are also a different bolt pattern on the manifold.
Mike Murphy
Melbourne Australia
Old 05-08-2005, 09:44 PM
Thanks for the offer guys. I am a long way away from an engine (probably 12 months at least), but wanted to understand if the LS2 was an option, which it seems it may be.
Can't want to start bolting bit's to it to have a billy cart, then the overpowered go kart later on
Maybe soon ....
Old 05-08-2005, 10:31 PM
boxhead's Avatar
You will enjoy sitting in the chassis and making noises.
Just wear a bib to catch the spit and dribble.
Cruising in 5th
Old 05-09-2005, 02:26 AM
I may have to go and record some Cobra's at a race day or s skid pan day and put the recording through the ghetto blaster in the garage.
Does anybody have any dimension drawings for the rear shock mount brackets for the CR. I could buy them front Ian, but I am going to have to get my welding skills back up to scratch (sit on an office these days), so I would like to make them myself.
Any help, suggestions or sledging greatly appreciated
Maybe soon ....
Old 05-09-2005, 02:46 AM
boxhead's Avatar
Here is a picture from my gallery showing the lower shockie mount, I have made my mounts so the shockie is moved further inboard.
I feel that I am going to have to get stiffer rear springs than where recomended by Ian, this I suspect is due to leverage affect of moveing the pivot inboard.
The springs as recomended are probably ok if you mount the shockie straight above the normal mount.
In this second pic you get a better idea of how much further inboard they are mounted
While everyone is looking at this picture can you all give me your opinions regarding the fact that I have applied urethane to the mount between the control arm and the mount, I left the car with full weight overnight to allow the urethane to dry.
I did this as in normal driving position all the weight of the vehicle is transfered through the control arm but when lifting the vehicle of the ground the mount would lift away from the control arm by approx 3mm.
Now nothing moves.
Thoughts and ideas would be appreciated.
Cruising in 5th
Old 05-09-2005, 03:22 AM
Cobra Make, Engine: Classic Revival, LS1, Shift kitted auto, high stall, AU LSD rear.
Churchy
I have a couple of photos in my gallery of the rear mounts.
I have drilled and tapped a m8 bolt to secure it.
Congradulations and have fun I am!!!!
Gav
Old 05-09-2005, 04:32 AM
Here's some pics of my rear shock mounts. A bit of a different approach to Davids but they seem to work OK. Once the bolt goes in they don't budge a milimeter.
Thbody of the mount is made from a section of tube that has the same ID as the OD of the knuckle on the lower control arm. It's a very snug fit over the knuckle.
On this last one I've modified the brackets where the shock mounts to so as to bring the bottom of the shock in a bit. I didn't have much clearanve left onec I fitted the 11" rear rims.
Mike Murphy
Melbourne Australia
Old 05-09-2005, 08:13 AM
BMK's Avatar
BMK BMK is offline
Churchy
Well done. Enjoy the build.
...hope you understand all the above..
Bernie
Bernie Knight
Old 05-09-2005, 08:16 AM
BMK's Avatar
BMK BMK is offline
Boxhead
Off the topic/Thread...
Did the 'dogs' arrive safely and all intact. Sent ages ago, via 'Australian Post Express' - guaranteed overnight deliver to your work..
Bernie
Bernie Knight
Old 05-09-2005, 03:25 PM
boxhead's Avatar
Yes thanks Bernie, they did get here very quickly, they couldnt wait to get out of the bag.
Cruising in 5th
Old 05-10-2005, 02:08 AM
BMK's Avatar
BMK BMK is offline
Boxhead
Dogs are like that..
Bernie
Bernie Knight
Old 05-30-2005, 05:03 PM
Made the final payment yesterday. Car trailer is booked for this Saturday, we shall be at Ian's yard, at 8.30 banging on his gate.
Will post pictures of Pete and I sitting in the chassis next to the magic fridge, just dribbling...
Boxhead, we have decided not to go for bibs, want to get the whole dribble.. vroom, vroom experience.
Maybe soon ....
Old 05-30-2005, 06:33 PM
pneall's Avatar
Mark, Peter,
Congrats, at last its all going to happen.
Phil
Old 05-31-2005, 03:35 AM
Cobra.au's Avatar
Cobra Make, Engine: Classic Revival, Gen3 ls1, Vortech T-Trim, Motec, tremec M12, wilwood brakes.
Looks like the fun, sleepless nights, skinned knuckles, hair pulling, and other Cobra building associated behaviour is about to begin.
Craig W
Craig W
Central Coast NSW
Old 05-31-2005, 04:57 AM
boxhead's Avatar
I am sure you will enjoy every minute of the above listed activitys just like the rest of us
Cruising in 5th
Old 05-31-2005, 06:30 AM
Cobra Make, Engine: classic revival 302w
congratulations churchy i got mine 3 months and enjoying every minute of it even the frustrating stuff
check out demon tweeks for shocks wicked service and price there in the uk but
jess
Old 05-31-2005, 06:49 AM
Cobra Make, Engine: LA Exotics, 351C/T-5 trans. Guardsman Blue
CONGRATULATIONS!!
Old 05-31-2005, 04:45 PM
Leeroy's Avatar
well done Churchy bet you wont sleep to well for the next few nights. Best feeling of all driving home with a Cobra hanging off the back of your daily driver (in Bernies case a Cobra towing a Cobra ) look forward to your progress and any advise you need
Leeroy.
