February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
  #21 (permalink)
Old 07-16-2006, 02:39 AM
Cobra Make, Engine: Classic Revival. LS1, T56, Billy Cart
Default Bolted up
Boxhead,
Here is the final product all bolted up and ready to "not" sway ...
  #22 (permalink)
Old 07-16-2006, 11:36 PM
Cobra Make, Engine: Classic Revival (under construction)
Hi Churchy
My parcel turned up today. They look great.
The invoice must have fallen out of the jiffy bag. Please let me know the cost.
Many thanks again for this great job.
Philip Chisholm
  #23 (permalink)
Old 07-17-2006, 02:35 AM
Hi Phil,
Thanks mate, you have a PM
  #24 (permalink)
Old 07-17-2006, 04:24 AM
boxhead's Avatar
Mine arrived today aswell, But I had the same problem as Phil C in that the invoice has become detached from the parcel, let me know what I can send back.
Cruising in 5th
  #25 (permalink)
Old 07-17-2006, 05:43 AM
Aussie Mike's Avatar
Hi Churchy
Do you have any clearance problems at full lock between the little link bar and the spindle/upright? looks like it would be tight but it's hard to tell from a pic.
Mike Murphy
Melbourne Australia
  #26 (permalink)
Old 07-18-2006, 03:20 AM
Mike,
The picture does not do the clearance justice, but your right it looks close in the picture. The top sway bar mount is about 50mm forward from the piece that juts out of the stub axle carrier and the clearance to the inside radius of the rotor (330 x 28) at full lock is about 25 mm.
When I read your post this morning, I was not sure of all those, so I have been waiting all day to get home and measure it ..
  #27 (permalink)
Old 07-18-2006, 03:49 AM
Cobra Make, Engine: Clasic Revival
Churchy,
Is it to late to put in an order in for those Al front thingy things.
Regards
Troy
  #28 (permalink)
Old 07-18-2006, 04:43 PM
Troy,
No problems, I can certainly make a set for you.
It may be a little delayed, as we are rebuilding the engine and I do not want to get little bits of aluminium floating around the garage whilst the engine is a block and lots of other little bits that I have to work out where to put them.
So once the engine is back together and sealed, I can start up the lath and mill again. Should be around the middle of August (hopefully).
  #29 (permalink)
Old 07-18-2006, 06:19 PM
Cobra Make, Engine: Classic Revival, LS1, Shift kitted auto, high stall, AU LSD rear.
I was in my local holden dealer today and I am intending to use a cut down VY commodore stabiliser bar connecting pin. It has a ball joint or knuckle on top for the bar and a thread below. It will need to be cut shorter and re threaded but should fit great.
I'll post pics as I get closer.
Gav
  #30 (permalink)
Old 07-18-2006, 07:37 PM
Cobra.au's Avatar
Cobra Make, Engine: Classic Revival, Gen3 ls1, Vortech T-Trim, Motec, tremec M12, wilwood brakes.
Originally Posted by Troy O
Churchy,
Regards
Troy
Welcome Troy O
Good to see another Classic Revival builder
Craig W
Central Coast NSW
  #31 (permalink)
Old 07-19-2006, 01:20 AM
Thanks churchy, give us a bell when you get around to it.
Cobra.au I have been a member since the begining of 05. A mess up with the club site, work travel comitments and telstra bigpond have left little time to catch up with members let alone my car. I hope to have more club input in the future.
Regards,
Troy
  #32 (permalink)
Old 07-19-2006, 02:58 AM
boxhead's Avatar
Welcome along Troy.
Dont forget to fill your details in on the Classic registery.
Cruising in 5th
  #33 (permalink)
Old 07-19-2006, 05:05 AM
Hi Troy, Welcome back.
I've got Troy's details and I'll be posting up a new version of the Classic Revival register soon. (along with a few other updates).
Mike Murphy
Melbourne Australia
  #34 (permalink)
Old 07-19-2006, 10:28 PM
PCC's Avatar
PCC PCC is offline
In preperation of receiving my aluminium thingies from Churcy, has anyone fitted one of the Pedder's Sway Bars on a DRB with Jag suspension?
If so, which fitments do I need to fix the bar to the aluminium thingie
PCC (Peter Craig)
Keep the sun shining
