November 2024
Old 02-06-2007, 03:07 PM
Shelby400's Avatar
Cobra Make, Engine: Homebush. Lexus quad cam V8, R154 Supra box. Oh what a feeling.
Default Battery
After 3 years of not getting much use my battery isn't what it should be.
I am looking at alternatives and was wondering what you guys are using. I am limited for space and would like to get the smallest possible battery available.
Your thoughts are appreciated.
Brett
!!Its good to be stroked but i'd rather be blown!!
Proud member of the Bclub Central Coast chapter
Old 02-06-2007, 05:26 PM
400TT's Avatar
I'm using Odyssey PC925. Not the smallest, but has plenty of cranking capacity, handy for tuning & track work, where you have to perform a few starts in a row. This has replaced an older PC800 that had an abused life, lasted 5 years.
A few guys with Lexus engines have been using smaller Odyssey batteries, no sure what sort of life they are getting out of them.
Also using a proper auto-charger, plug it in and forget about it. I reckon this is the secret to long battery life.
http://www.dse.com.au/cgi-bin/dse.st...uct/View/M9826
www.absolutepace.com
Old 02-08-2007, 03:43 AM
I have learnt that Oddesy batterys tend to fail due to the plates breaking away from the terminals. A very expensive battery becomes useless and worthless in minutes. Look after them ! I use an Optima jobby...so far so good. Its been sitting for two years and has held a near full charge so far. I gave it a recharge recently (8 hours) and it didn't really need it !
Smithy
Old 02-08-2007, 03:52 AM
Leeroy's Avatar
I have the odessey also which not sure which model but gives around 1000C/A. I also had my first one after about 12mths??? They replaced it without any questions, since then no trouble but for a $350+ battery you would expect some support. Good size and fully sealed dry cell and cranks like a schoolboy
Old 02-08-2007, 04:07 AM
PCC's Avatar
PCC PCC is offline
Mine's a small Odyssey tucked away under the passenger footwell.
First one lasted 3 years but did run down on a few occasions due to a faulty alternator.
This one cranks well and to date has never failed. I have charger leads running off it into the glove box, but hardly used it.
The battery is about half the size of a standard one.
PCC (Peter Craig)
Keep the sun shining
Old 02-08-2007, 05:12 AM
Cobra Make, Engine: The one leaving fat black marks
Mine is a Braille battery... smallest size, highest output...
I got it from a place in SA that are the distributors, I cant remember what they are called though... I'll find their card.
http://www.brailleauto.com/index.html - edit, they have added carbon fibre ones now! Cool.
Todd
