05-24-2007, 06:29 AM
QLD
Cobra Make, Engine: Harrison Cobra, SC540 Roadster
Craig,
It would be nice to have the wider tunnel, this would also be useful to get the exhaust higher.
Sideshow,
The speed sensor is the one with nylon gear and permanent magnet in the head which is just the for the speedo.
If you take a picture it would be good, thanks. I have about 40mm between the chassis and the gearbox.
I have seen a picture of the VSS on IJZ manual Soarer which is low profile and would be suitable, but i am unsure where I would be able to get one. Would the VSS from a MKIV Supra auto be the same?
Warren
