January 2025
26 27 28 29 30 31
  #41 (permalink)
Old 05-17-2008, 10:43 PM
martrogers's Avatar
Cobra Make, Engine: Homebush fibreglass
Tire Rack - Your performance experts for tires and wheels
Fred Helmuth [fred@tirerack.com]
Regards
Martin
  #42 (permalink)
Old 05-17-2008, 11:32 PM
400TT's Avatar
The HTR Z IIs are very good tyres. I've heard very positive comments from people using these.
The review comparing the new HTR Z IIIs to it's competitors sounds very promising.
A New Name Challenges the Max Performance Summer Category
Aus RCRs are supplied rolling with HTR Z IIIs where sizing permits(basically for everything except some of the very large rear rims).
www.absolutepace.com
  #43 (permalink)
Old 05-19-2008, 01:15 AM
Merv and Sharon's Avatar
Brilliant! Thanks Craig and Martin. Will order in the next few days!
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
  #44 (permalink)
Old 05-19-2008, 09:40 PM
400TT's Avatar
Merv, I've just ordered some more Sumitomo's from Tire Rack. 58 to be exact. Got your order in yet?
  #45 (permalink)
Old 05-20-2008, 03:22 AM
No sense in doing things by halves Craig!
Ben
  #46 (permalink)
Old 05-20-2008, 04:41 PM
Thanks Craig. I just had an email from Fred H at Tire rack:
The 235/45/17 Sumitomo HTR Z III is $92.00 per tire.
The 275/40/17 Sumitomo HTR Z III is $111.00 per tire
So I haven't ordered yet but was going to do it over the next day or so. Is there a best way to reduce/avoid duties and taxes?
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
  #47 (permalink)
Old 05-20-2008, 05:12 PM
Tenrocca's Avatar
Will work out under $1000 so no duties or taxes
  #48 (permalink)
Old 05-20-2008, 05:13 PM
stephen low's Avatar
Merv
I am led to believe that if you keep the purchase cost below $1000, AUD I assume, you avoid paying GST?, I might be wrong. I know the $1000 figure is right for avoiding something!!
You also need to have stickers on the outside of the box saying made in the USA to help eliminate or reduce some dutiable value I can recall. To do with so import relationship with the US.
Hopefully someone with far better knowledge can ping in an illuminate us both, as I too am looking at rims and tyres import at some stage.
Steve
slowy
  #49 (permalink)
Old 05-20-2008, 05:20 PM
Missed by that much.....
But I've just found my notes <$1000 AUD no GST payable, made in the USA no import duty payable.
Multiple material orders then need a bit of finesse as to how many shipments, and cost, versus what you can avoid paying here in duties and taxes for less than $1000 imported.
Anyone know how hard do they look into containers importing cars back from the US?
I have an opportunity via this method that will not cost me any shipping but I don't want to stack the car with too many goodies and get my mate in the sheite!!
slowy
  #50 (permalink)
Old 05-18-2009, 07:38 PM
sambo's Avatar
Bill sent me the details of the ones he ordered for his Harrison (his tyres are: 235/45/R17 Front and 275/45/R17 Rear.
(2) Vintage 60 17x8 with a 4-7/8" backspace / GM bolt pattern $599.50
(2) Vintage 60 17x9.5 with a 5-1/4" backspace / Ford bolt pattern
$639.50
This question goes to people who have fitted 17" wheels to their Harrison - Merv, Schipps, etc - and particularly those who used the offsets Merv (and others) provided, above.
Using a straight edge ruler and spirit level against a 17" wheel fitted to my car, the front wheels using Merv's offsets would stick out a good inch at the top of the front guard. Rear wheels looked OK.
With Eli's (Vintage Wheel Works) help we worked out that the offsets for my car need to be:
6" backspace on the front (vs 4-7/8")
5.5" backspace on the rear (vs 5-1/4")
I know Schipper's wheels were cutting it mighty fine on clearances, so just wondering whether others have had a similar experience with the offsets on a Harrison? The fronts are almost 3cm too wide for my car which just doesn't seem right.
Thanks
  #51 (permalink)
Old 05-19-2009, 03:17 AM
Could be Sambo. Bill G used the same wheels and tyres as mine and was registered OK up here and my engineer had no problems with mine (but I have not done QT as yet). They seem fine on my body but are very close to the margins. Harrisons can vary a little also.
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
  #52 (permalink)
Old 05-19-2009, 03:22 AM
Your backspace may be fine.
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
  #53 (permalink)
Old 05-19-2009, 04:23 AM
Default How hard they look in containers
Steve, way back I was buying bits for a mustang and was dealing with a bloke in Sydney. He was a bit slow in bringing my bits back so I rang. His missus told me that he was being held up in California with export problems.
I waited another month and rang again. Same story with apopogies. So I asked for my money back.Got it and forgot about the problem. I went on to find other importers. Finally found one really good man who actually bought the parts himself then sent them home from the USA. He told me that the other bloke was in jail in the US for trying to export a stolen mustang. He was finally released and forbidden to return to the USA for ever. The customs and police regularly check containers. They have a dedicated "team" that does only that task. That was about 12 yrs ago. I doubt they've got slacker.
  #54 (permalink)
Old 05-19-2009, 04:32 AM
martrogers's Avatar
Sambo
I have 17" Vintage Wheel Works wheels but not on a Harrison so I dont know if this will be of interest to you.
Anyway, I got Eli to send me dimensioned cross sections of the rims - it turned out that the backspace is measured from the inside of the rim (where the tyre presses against). The rim then turns out 12mm and the tyre bulges out beyond that.
This is probably important if you're tight for space.
Let me know if you want me to send you the diagram.
  #55 (permalink)
Old 05-19-2009, 05:13 AM
sambo's Avatar
Thanks Mart. Yes we suspected that might be the case and Eli confirmed it when he wrote back saying the 8" wheels were actually 9" and the 9.5" are 10.5".
We worked out my frontspace using a wheel of known offset with tyre fitted, allowing for tyre bulge to clear the wheel arch. But it would be great if you could send me that diagram please - helps put the mind at ease! samps8@hotmail.com
Thanks
  #56 (permalink)
Old 05-19-2009, 05:46 AM
Krait's Avatar
Hi Paul,
My Harrison has Vintage Wheels Inc knockoffs mounted with Sumitomo's.
Fronts 17 x 8.5 with 5.00 backspacing
Rears 17 x 10.5 with 5.00 backspacing
I have the fabricated IRS so may not be valid for a Nissan rearend. The knockoff adapters may also screw up the measurements
Geoff
  #57 (permalink)
Old 05-19-2009, 06:15 AM
sambo's Avatar
Thanks Geoff. I seem to remember someone saying the Vintage wheels wouldn't fit the standard Harrison setup (eg, R32/33 rear end) but I might send them my measurements anyway - their wheels look even better than the ones from Wheel Works.
Edit: just had a look and their maximum backspace of 5" on the fronts wouldn't be enough.
  #58 (permalink)
Old 05-19-2009, 03:26 PM
07cob's Avatar
Default Options...
Originally Posted by sambo View Post
Just had a look and their maximum backspace of 5" on the fronts wouldn't be enough.
Hey Paul
Have you painted your car yet? If not, would you consider extending the front guards to accept the Vintage Wheels? If I recall correctly, it is only the fronts that would cause a problem and the 5" max backspace would leave the tyre around 1" proud of the arch. I have seen other vehicles with extended guards that look quite nice.
Just a thought ...
Geof
  #59 (permalink)
Old 05-19-2009, 05:35 PM
sambo's Avatar
Thought about that too Geof but prefer not to at this stage due to the added cost of those wheels and body work. Might rethink after the tax return comes in!
  #60 (permalink)
Old 05-19-2009, 05:50 PM
Is this an engineering check item or a QT one? Mine seem to be OK since the suspension has been aligned.
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
