January 2025
26 27 28 29 30 31
  #21 (permalink)
Old 07-03-2008, 01:40 AM
martrogers's Avatar
Cobra Make, Engine: Homebush fibreglass
Thanks guys, still not sure but I'll take myself over to the Factory 5 site and perhaps talk to a painter or 2.
  #22 (permalink)
Old 07-03-2008, 02:40 AM
stephen low's Avatar
Martin
Get some good advice on the process and have a go yourself.
Once prepared for primer with all bits filled and sanded ready for primer paint, you can always ellicit advice as to whether the finish is good enough, and given the cars are all curve, it's either a small palm sander always on the move or hand sanding, either way a fair bit of time.
I've seen the finish of an amateur prepared car and it was excellent after spraying by a professional mob.
I've learnt off boat preparation for paint, lots of time and patience and you will get a good result, for the price of your time. This saves your money for that quality paint finish, the bit it sounds like you want a professional to do anyway.
Just get some good preparation advice first.
slowy
  #23 (permalink)
Old 07-03-2008, 03:17 AM
Default Paint
IMO the paint is the most important thing on a car.
It takes 4 years to learn to be a painter/beater!!!!
There must be a reason for that.....
The paint cost alone are around $2k plus the paper and stuff.
STIFFY
  #24 (permalink)
Old 07-03-2008, 02:26 PM
400TT's Avatar
Originally Posted by Plums View Post
I didn't let the body cure for long enough before painting.
Sticking the body out in the sun under black plastic, certainly speeds up the curing process. It's a hassle, but well worth it.
www.absolutepace.com
  #25 (permalink)
Old 07-03-2008, 06:40 PM
LoBelly's Avatar
The body on my car sat in a shed for 15 years (this may not always be practical)
fortunately the style didn't date in that time
LoBelly
  #26 (permalink)
Old 07-03-2008, 07:31 PM
sambo's Avatar
Mine's 12 months old and has spent several weeks in the sun off and on during that time. Plenty of areas where the bog has shrunk and/or cracked.
  #27 (permalink)
Old 07-04-2008, 01:45 AM
Cobra Make, Engine: DRB,Ford Tickford 302 220kw with BTR 4 speed auto, 3.9:1 LSD
From what I have seen/heard it is recommended to bake the fiberglass body in an oven before painting. It is not recommended to oven bake after painting.
Cameron
