December 2024
Old 02-14-2009, 07:54 AM
fastraxsg's Avatar
Evryday is a roadstr day
Cobra Make, Engine: RHD Hurricane street roadster HM1081 aging nicely in the garage
Default Threebond
I've got a problem that I was wondering it any of you have some thoughts.... The kit I bought came with a poly tank with a rubber gasket to put in between the metal filler neck and the tank. The guys stateside have lottsa trouble with it so they switched to paper gaskets and use a sealer called SealAll but I can't get it here in Indo. I can get one called ThreeBond which is a Japanese brand produced under license here. I thought I recalled seeing it in Perth the last time I was in Aust. My plan is to mount the filler on top of the poly tank, use a paper gasket and this ThreeBond "semi-drying elastomer, Liquid gasket rubber-based" material. It says on the package, "it excellently resists heat, oil, gasoline and particularly LPG.....designed to form a layer thick enough to work efficiently on uneven joint surfaces"
Whatcha think?
Ken
aka Fuzzy ............... "It is not the return ON my investment that I am concerned about; it is the return OF my investment".......from Will Rogers
Old 02-14-2009, 01:40 PM
Merv and Sharon's Avatar
Hi Ken. I was in Jakarta 2 weeks ago and will be again next month. Met a guy who had seen a Cobra around town there (I also read in the Jakarta Post that there are three Enzos!).
Hard to say if that particular sealer would help - others may be more knowledgeable on that - but the hot weather there and especially the humidity may influence the type of gasket?
These guys: https://www.acehardwareoutlet.com/(g...onExpired=True
Say that they ship internationally.
Hope to catch up at some time!
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 02-14-2009, 11:41 PM
boxhead's Avatar
I have never used threebond in a petrol sealing use, but have used it extensively in gearbox case assys, it is OEM spec Toyota stuff on gearboxs, Transfer cases, Diffs etc.
I would wipe some on a piesce of clean metal then sit it in a container of petrol over night, this will let you know if it is going to break down in petrol.
Cruising in 5th
