February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 06-26-2009, 04:38 AM
Zedn's Avatar
Default Looking for info on RCM
Hi,
I am currently researching cobra kits and have spent a bit of time reading this forum but not yet posted.
There is an RCM kit up for sale at the moment and i am wondering if anyone on here has any experience with this kit? If so, can i get some opinions, good part bad parts etc. I tried the search but it seems to also give posts about RMC so becomes a lot of posts to trawl through.
I am in NSW (unfortunately from what i read!) so i think the motor I use for it would be the 6lt LS2 as these are NSW friendly (i think). Does anyone know if this will fit with this kit? Would i have trouble getting this model kit registered in NSW?
Also is there any structural testing that is required for engineering (torsion and beam)? If so should this come with the chassis?
I really dont want to buy a Body and Chassis because they are cheap and then find i end up spending heaps of money on engineering.
Hoping someone can offer some advice.
Cheers.
Liam
Old 06-26-2009, 06:46 AM
G'day Zedn, Find a Signatory Engineer first..they are up to speed with kits and their faults etc. It may cost a little but worth every penny.
Old 06-26-2009, 06:57 AM
Hello,
I do not know much about the RCM kits, but if you want to talk Cobras give me a yell. I recently registered a Classic Revival kit.
I am in the Hills area.
Ben
Old 06-26-2009, 07:36 AM
Zedn's Avatar
Hi Beejay,
I am over on the Northern Beaches. Which RTA engineer did you use for your CR? It may be worth me giving them a call next week. What documents did you provide to the engineer? I believe the CR comes with supporting documentation for the chassis.
Is it a case of them examining the chassis or do they require a torsion and beam test report?
The car i am looking at comes with no docs on the chassis. I work in quality management certification and my qualification is Civil engineering. I have experience with product certification to Australian standards and i assume this is very similar. I imagine the engineers are interested in design of the chassis, materials used, quality and qualification of the welding. Or is it all performance based? I dont want to buy a kit for cheap and then spend so much on engineering that i could have just bought the CR kit who are half hours drive away.
Old 06-26-2009, 07:51 AM
stephen low's Avatar
Zedn
I'd be surprised if RMC didn't support you if you bought the kit and chased engineering information later. Presuming of course the evilbay car is an RMC.
I bought a second hand G-Force (also made in WA) which is a bit of an RMC clone, without engineering papers and was pleasantly surprised by the G-Force owner's support in sending me a copy of his standard report.
This helped me successfully through engineering.
Agree though that if you can get a signatory vehicle engineer on board first you will have access to advice on the correct up to date engineering requirements you need to meet.
Best of luck in your search!!
slowy
Old 06-26-2009, 08:53 AM
Zedn,
Your decision should be made on which kit suits you best.
I am a mechanical engineer - and this has been the most annoying, frustrating yet enjoyable experience I have come across. I have made some great mates and along the way built a car too.
I just happen to know a couple of guys on the Northern Beaches that have built a car recently and could give you some good advice. I am sure they will pop up soon.
I am certainly bias, but take a look at the latest Classic Revival Kit, the LSX engines bold straight in and they have a quality chassis and body. If I were to build again that would be the one I would go with.
Ben
Old 06-26-2009, 03:31 PM
Smile
HI Zedn,
Call Laurie Bongailas on 03 9887 9997. If it's an RCM kit then Lauire would have supplied it originally. You can't go wrong with these kits. Easy to build and handle fantastically well.
Old 06-27-2009, 02:31 AM
martrogers's Avatar
Cobra Make, Engine: Homebush fibreglass
Hi Zedn.
I'm in Forestville and went through certification last year. Send me a PM and I'll give you my details if you want to come around and have a look/chat.
Martin
Old 06-27-2009, 07:25 AM
Zedn's Avatar
PM sent.
Thanks!
Old 06-27-2009, 01:24 PM
Cobra Make, Engine: RCM. L98
Talking
Hi Zedn,
Give Laurie a call he will help you. He has built about 80 cars around the country, his cars handle well. The good thing about Lauries cars is he will help you all the way with your build.
Old 06-27-2009, 07:27 PM
BMK's Avatar
BMK BMK is offline
RCM is Laurie
RMC is the WA based Co.
Both well represented with owners who have completed cars.
Bernie Knight
Old 06-28-2009, 04:52 AM
Thanks Bernie, re-reading the post I realised I'd misread the first time round must have been those grapes in the water I was drinking at the time!!
slowy
Old 06-28-2009, 09:20 PM
Zedn's Avatar
Thanks for the replies everyone. I have spoken to an engineer (Kevin at Wyong) and apparently the Torsion and beaming testing is not going to be too greater expense (unless it keeps failing). Judging by the reading i have done on here and in my copies of Kitcar magazine from last year, it should pass or require little work to pass.
Liam.
Old 07-03-2009, 05:08 AM
Ha Ha Ha my beaming & torsion test results supplied by RMC were for some other vehicle. My engineer looked at them and laughed. He said that the chassis would have to have had 'slices' cut in it to be as flexible as the test results stated. All was sorted and both engineer & RTA were happy.
