Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 07-20-2010, 12:27 PM
lnfletcher's Avatar
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
Default Rear four links squeaking!
Not a big problem, but wanted to see what everyone else has done to fix this problem, or even if they have had it.
I have a narrowed 9" with square tube 4 link setup. I have a dry rubber squeak when going over bumps. I sprayed some silicone lub on the joints that seemed to help slightly, but I really don't want to break them down and slober grease on them to quiet them.
Has anyone else had this problem and how did you solve it?
Old 07-23-2010, 10:27 AM
Cobra Make, Engine: B&B,351w
I have the exact same problem and was wondering how other people are addressing this. Looking forward to some replies!
Old 07-23-2010, 10:51 AM
keep spraying the lube to them.....if they are dry it may take a few times to get the lube all the way through to the dry spots.....
