Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
November 2024
Old 07-10-2011, 10:37 AM
Wbulk's Avatar
Cobra Make, Engine: 66 Cobra
Default Lower B&B Radiator Hose with a 302
After being off from building the car for about eight months for various reasons I am trying to get back into it. I'm evaluating how to do the lower radiator hose. I decided not to use the stainless flex hose as the joint at the radiator needs to angle up about 22 1/2 deg. at that point without going down further. It looks like I will go with the exhaust tubing method with the 90 deg. bend going up to the water pump.
I am guessing I will go with the standard water pump lower hose and cut it to connect to the tubing going down. Do any of you know the part number for the short 1 3/4" hose connecting the radiator to the tubing? I am trying to save hours of looking at hoses at the parts stores. It looks like it needs a 22 1/2 deg. bend in it.
The reason I decided to go with the tubing is it seems to be the best method to get it up higher out of the way. I may even crush it a little with my press where it goes under the frame to get it up higher. If any of you have pictures that would help.
Thanks.
Wayne
Old 07-10-2011, 10:42 AM
Rick Parker's Avatar
THis is not the same as your application but shows what can be done.
Rick
Old 07-10-2011, 10:58 AM
Wbulk's Avatar
Rick, that is good work.
Wayne
Old 07-14-2011, 04:31 PM
Wbulk's Avatar
I lucked out and found the right hose pretty quick. I found that Gates hose 20609 works really well and you can get the upper and lower pieces out of this one hose. This is a pretty common hose and fits a ton of Ford vans and some dodges.
I did what others had done and got a piece of 1 3/4" aluminized muffler tubing bent. I had seen that tread on making a tool that would dimple the end of the tubing to make a hose stop if that's what you call it. I had also seen over on the FFR forum where a guy used a few wraps of wire and some JB Weld to make the stop. I decided to do a version of that.
I noticed that coat hangers were just about the right size to make the stop. I bent them around a 1 1/2" piece of tubing and let them overlap. I then forced them over my 1 3/4" tubing and cut them so the two ends met. I sanded the tubing and the coat hanger with 80 grit and put a coat of JB Weld around the ring. I think it should work pretty good. I will give it a try.
Wayne
Old 07-15-2011, 01:37 PM
lnfletcher's Avatar
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
It's amazing how many different ways we find to do things while building these cars!
Very interesting, I'll be interested in knowing how this works out.
Old 07-21-2011, 09:30 AM
Wbulk's Avatar
Default Finished Hose
This is the finished hose. No doubt the stainless flexible hose would have looked better but I believe at the connection of the radiator it would have hung down lower. As it turned out it is all higher than the bottom of the main frame. I guess I am more practicle than flash.
Wayne
Old 07-21-2011, 09:53 AM
NFLDMNBB's Avatar
Cobra Make, Engine: B&B, FR302
Looks great! Actually it looks just like mine. The only difference is that I have a friend that’s a Tinner. He was able to roll a bead on each end of the pipe for me. I recently installed a new Griffin Aluminum Radiator. The bottom hose always leaked. When I disassembled it the bottom tube had a straight cut on one end and a flare on the other without a bead.
On your car is the radiator connection smaller diameter than the tube diameter? Mine is 1.5” on the Rad. and 1.75” tube. I really like your idea of the hanger bonded with JB! That should do the job, very creative!
Roger
Old 07-21-2011, 12:41 PM
lnfletcher's Avatar
Hey Wayne, It's hard to tell how much space you have between your frame and the tube, but you may want to put a rubber pad in between.
It took me almost a year to figure out what that rattle was when I punched it and the torque caused the two to rattle together!
It looked fine sitting there without going down the road!
Old 07-21-2011, 05:08 PM
Wbulk's Avatar
Roger, mine is 1 3/4" on both the hose and the radiator.
Larry, it's just about 5/16" of a gap. I was thinking about that, thanks for reminding me. The other option I was pondering was just welding a bracket to the tube and then bolting it to the under side of the K member.
Wayne
Old 07-22-2011, 04:54 AM
lnfletcher's Avatar
I took the easy way out. All I did was to cement a part of the radiator hose that I had cut off to the top of the tube where you couldn't see it. Solved my raddle and allowed the tube to move as much as needed.
Old 08-23-2011, 12:35 PM
Andreas's Avatar
90'd out of the radiator towards the passenger side and went over the cross member. it doesn't sound like anybody else has had problems with the lower hose getting hit but i didn't want to find out the hard way.
Mom said she would kill me if I got a bike...
So I brought home a Cobra.
Old 08-23-2011, 02:10 PM
Dwight's Avatar
Smile
I'm working on a 351W B&B in my shop. Just a bunch of maintain items.
Last week I reworked the lower tube by cutting, reshaping and welding it back together so the radiator end is 1 1/2" in diameter to match the radaitor.
I think I will install a rubber pad between the frame and tubing. Thanks for the tip.
Dwight
