Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
January 2025
26 27 28 29 30 31
Old 12-10-2011, 07:57 PM
Cobra Make, Engine: b&b
Send a message via AIM to erudolph
Default 8.8 axle
Hi guys, A new owner here. In sept i bought a completed car. The previous owner installed a brand new 8.8 rear but never thought to have it narrowed. Now its my problem. Do any of you know what width of the b$b 9 inch is narrowed too. I will probably have be a custom size because of the wheel of the wheel size and offset. Also dealing with the running hot issue but have that decision almost made(taurus fan). Your help would be greatly appreciated. Ed
Old 12-11-2011, 11:17 AM
GREENSNAKE's Avatar
You have any pictures of your car showing the wheels from the back?
Old 12-15-2011, 10:47 AM
Thanks,I'll try to attach some photos but i get that the file size is to big. Ed
Old 12-15-2011, 12:46 PM
On your post at the end it mentioned Bryan Anderson. Is he with B&B or is he at lonestar Classics?
Old 12-15-2011, 01:53 PM
Barnsnake's Avatar
Cobra Make, Engine: LoneStar LS427 , 427 Windsor
Brian Alexander is Mr. LoneStar Classics.
Jim
A Gnat! Quick, get a sledgehammer!
Old 12-29-2011, 06:54 AM
jbmatth's Avatar
Cobra Make, Engine: B&B 351w
I am glad you asked this question, I'm in the same boat, my 8.8 is factory width and the tires rub on the wheel wells under hard bumps. As for the fan, I installed a Mark 8 fan from fanconversion.com, and it works great, even when it was 110 here in Ok this summer it never got hot.
I believe that any man's finest hour, his greatest fulfillment of all he holds dear, is the moment when he has worked his heart out in a good cause and lies exhausted on the field of battle - victorious.
Old 01-08-2012, 07:29 PM
Default 8.8 rear
Ed here, I wound up measuring inside clearances from the tire side wall and took it to mike fortes parts connection to be narrowed 4''. 2'' per side. For comparison sake the cost will be 510.00 with new axles. He is very knowlegable on the cobra and has a very extensive shop, including an engine dyno. Check his website. Ed
Old 01-09-2012, 08:58 AM
Wbulk's Avatar
Cobra Make, Engine: 66 Cobra
erudolph, I checked my notes and my 9" is 56 1/8" axle flange to flange that the rotors mount to on my B&B. Getting the back spacing just right for the various wheels is the hard part.
