Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
January 2025
26 27 28 29 30 31
Old 03-17-2002, 04:31 PM
jams's Avatar
Cobra Make, Engine: B & B
Default Electric Fuel Pump Location
Hello again,
For my application I need to use an electric fuel pump. Has anyone used one out there and if so where did you mount it?
Thanks for your help.
Old 03-17-2002, 06:43 PM
I have a B&B Cobra with a 302 engine at close to 350 Hp. I used the Mallroy Comp 70 electric fuel pump. I mounted it to the frame near the fuel tank, but in the rear differential area. I simply ran 3/8" brake line tubing to the engine. Mine works fine with a Holley 650 DP.
Steve
