Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
  #21 (permalink)
Old 03-09-2007, 08:15 AM
Cobra Make, Engine: B&B, 302 Ford crate motor
Default pmfranke
On Dusty Rhodes wheels did you notice he has an 8.8 abd you have a 9"?
There may be some difference in lenght so the offset of the wheels may need to be adjusred.
1993 Mustang Cobra
  #22 (permalink)
Old 03-09-2007, 10:21 AM
Cobra Make, Engine: B&B 351w
the rearend is a narrowed chev rearend, 54 1/2" from axle flange to axle flange
Dusty Rhodes
  #23 (permalink)
Old 03-10-2007, 07:59 AM
Default Dusty Rhodes
Thanx for the correction. I have a slight bind in the steering too. I didn't think it was bad enought to worry about but now that you mention it, what did you do to correct it? Your front sway bar looks perfect. It is from a '68 Camaro?
1993 Mustang Cobra
  #24 (permalink)
Old 03-10-2007, 10:24 AM
the swaybar is from an 1986 camaro. On the steering I cut the bracket off ( the one between the firewall and steering rack that holds the bearing), and turned it around so that it would be closer to the motor. problem solved.
Dusty Rhodes
  #25 (permalink)
Old 03-10-2007, 07:37 PM
pmfranke's Avatar
Cobra Make, Engine: B&B 351/402 Fi roller everything
mine is a 9" ford that's 54 1/2" also.my spring are too short (oil pan 3 1/2" clearance) so i'm looking for 10" free length.dusty's springs look like 2 1/2" id all the way up into the mustang II cup.Unlike mine that have two different sized ends 2 1/2" and 3 1/2"at the top. With the streight springs , there are alot more choices of length and rate. the Camaro sway bar does look perfect . how to mount to the tubular A arms is the next question.
the older i get the faster i was.
