Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 02-24-2007, 03:44 PM
BeasleyRB's Avatar
Cobra Make, Engine: B & B , 351W 400+
Default Transmission Mount for Small Block B&B Please??
I bought a 2530 Anchor Trans mount from Oreilly for my 351/Tremec. When installed it looked very "tall". The drive line angle looked excessive. Clois Harlan measured his mount and it is 1.5 inched tall. My 2530 is 2.75 inches tall. I went back to Oreilly and the counter man found a 2287 that is for a V-8 Grenada. It is 1.5 inches tall but is made from lighter material and is not as substantial. The angle is much better with this one but I am concerned it is not strong enough. Please search your memory and let me know what transmission mount you used on your B&B with a Small Block. I will post a picture of the two if I can. I think you can see which one is which. I would appreciate some feedback from you B&B trailblazers. Which transmission mount did you use.
Old 02-24-2007, 04:36 PM
BeasleyRB's Avatar
Sorry, the transmission mount that I think might not be strong enough is Anchor 2253. (The other number above is a motor mount) Bob
Old 02-24-2007, 07:57 PM
Cobra Make, Engine: B&B...351/393w
Default Trans Mount
I actually used a taller mount as well. I built some 1" solid block shims and lowered the transmission crossover member, worked great.
Old 02-24-2007, 08:33 PM
pmfranke's Avatar
Cobra Make, Engine: B&B 351/402 Fi roller everything
2351 is the wrong one. the little one 2253 is the one i used and it has'nt failed yet. only 600 miles though. I used good motor mounts , they take most of the torque anyway.
the older i get the faster i was.
Old 02-25-2007, 07:48 AM
dlampe's Avatar
Use the short one. There isn't that much torque on the trans mount. You will be fine. If your angle is not right on, you will have serious problems.
I can't believe you need to ask these questions with Clois around! I thought he knew EVERYTHING!
High Maintenance Racing Team
Run & Gun 2003 - 2013
Old 02-25-2007, 08:56 AM
BeasleyRB's Avatar
He does know everything and told me the lower one is the right one. I was just wondering if the lower one I have is the "right" lower one! Clois is a great guy and helped me put the engine in yesterday.
Old 03-01-2007, 07:21 PM
BeasleyRB's Avatar
For the record the 2253 is the one to use from Anchor. Prothane model is 6-1605-BL.
