Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 04-15-2008, 06:34 PM
Cobra Make, Engine: B&B, York 351W (Work in Progress), 07 Shelby GT # 0767, 09 Shelby GT500, 09 Shelby GT500KR #440
Default Drive Shaft Scatter Shield
After reading some of the posts of U-joints coming apart, I decided to make up a scatter shield for the drive shaft and wanted to share the end result for anyone who might want to do something similar.
The scatter shield was made out of 1/8 inch plates and then welded together. This will be bolted to the front drive shaft hoop and then brackets that will be bolted to both the scatter shield and the inboard seat belt plates.
The current pictures are the raw stock. Once I have all of the remaining small parts finished, they will all be sent off for powder coating so it should look a lot better.
http://www.clubcobra.com/photopost/s...9&ppuser=24713
http://www.clubcobra.com/photopost/s...8&ppuser=24713
Old 04-15-2008, 07:04 PM
Cobra Make, Engine: Backdraft #90, 351w,Tremec 3550, SB100 SOLD
Default D&m2
Nice work. That is one beefy part! Should be no worries now.
SkipB
Old 04-15-2008, 07:16 PM
jams's Avatar
Cobra Make, Engine: B & B
Thanks for sharing your work/pictures.
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
