Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
January 2025
26 27 28 29 30 31
Old 06-03-2008, 07:44 PM
BeasleyRB's Avatar
Cobra Make, Engine: B & B , 351W 400+
Default Rattle in Side Pipe
One of my side pipes has developed a rattle in it. I think I know the answer but is there anyway you guys know of to fix it short of cutting it apart and rewelding the core. I assume it has a glass pack set up inside of it. Mine is the B&B car with the ceramic coated system. The car only has 1600 miles on it. Expensive to replace if I have to.
Old 06-03-2008, 08:20 PM
woody2's Avatar
Cobra Make, Engine: B&B 302ci
I tapped my side pipe with a rubber hammer to find the part of the pipe
had the noise. Mine was bottom back. So I took it off the pipe and cut a
1 1/2 x 1 1/2 square out in that area and found a nice piece of old metal
slag. After removing that piece I mig welded my cutout back in. It's under the pipe so you don't see it. A litte thouch up with some high temp paint and good as new. I did try sheet metal skrews first thinking the inner pipe was loose but that didn't work.
Good Luck
Bruce
Old 08-24-2008, 04:18 PM
pmfranke's Avatar
Cobra Make, Engine: B&B 351/402 Fi roller everything
Mine has a rattle too really bugs me. my pipes are still black but i hate to cut them up just to fix a rattle.
the older i get the faster i was.
Old 08-24-2008, 05:02 PM
jwd's Avatar
jwd jwd is offline
Alot of guys have fixed the rattle by drilling a hole on the back side and putting in a long stainless steel screw. It's worth a try.
Jim
